Latest post 10-22-2008 2:40 PM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 10-22-2008 11:42 AM
    New Here
    Hi all
    Very new to the B&O scene, not sure if I can post the following within this section.
    I've come across a component system consisting of a turntable Beogram 5500, CD player Beogram CD 5500, Cassette deck Beocord 5500 and an amplifier Beomaster 5500. With two beolink 1000 remotes and Master Control Panel 5500.
    All in very good working order, was wondering how much are these worth.
    Replies appreciated.  Thanks in advance.
  • 10-22-2008 12:44 PM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Re: New Here
    Wecome to Beoworld !
    It all depends on their working and cosmetic condition. Also key is the condition of the stylus. Assuming they are working OK and cosmetics are good, then target prices (they sometime go for a lot more) should be
    Beogram £200
    CD5500 - £130
    Beocord - £30
    Beomaster - £80
    Beolinks - £35 each
    MCP - £90
    If they're mint then you can add 20 - 30% ish onto these prices.
    It's always far cheaper to by a whole system together than buying seperately.
    Good Luck!
    Cheers
    Nigel
  • 10-22-2008 12:57 PM In reply to
    Re: New Here
    Thank you very much.
    Very surprised that I can potentially sell the whole system in the region of £600!
    Is this system rare?  I take it that it is universally known as the Beosystem 5500?
  • 10-22-2008 2:23 PM In reply to
    • h1npw
    • Posts 776
    Re: New Here
    Hi
    Yep, it's a Beosystem 5500. It's certainly not rare - probably the most popular of that era of Beosystems. Be aware that CD players that have had a lot of use of this age will be prone to worn out lasers, and unfortunately replacements are not available. If you can afford it better to go for one of the later 6500 or 7000 systems. Replacement styli (just as good as the originals, if not better) are availble from a company in the USA called Soundsmith, although with the £ falling through the floor compared to the $, they're not cheap!
    Cheers
    Nigel
  • 10-22-2008 2:40 PM In reply to
    Re: New Here
    Not rare - I have two! I think £600 could be a little optimistic though - a bit under £500 in my opinion if in good condition. Problems are commonly seen with the Mute relay affecting one channel on Speaker 1. Cassette belts are another issue.
