Latest post 12-19-2007 5:01 AM by Ignace. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • 12-14-2007 4:58 PM
    • caBur
    • Not Ranked
    • Joined on 12-14-2007
    • Posts 12
    Beo4 remote question(s)
    Not sure if i'm in the right place, but anyway..
    I've bought myself a wii which i've plugged in to my B&O Avant (AV connection) which i also have a B&O stero connected to.
    I've added the V.AUX to my Beo4 and i can play without any problems. Except one.
    I've always been able to connect my sound from the TV to the stero (Radio -> AV -> TV and all that) But i don't know how to make it work for the V.AUX sound.
    Is it possible and how do i do it?
  • 12-14-2007 6:13 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beo4 remote question(s)
    Hi and welcome to the forum.
    Can you get the sound from the Wii through the speakers of the Avant?
    Is the Wii connected with a fully wired Scart?
    Which model Beo4  do you have? I guess it is Sat AV CD on the second row of buttons.
    Andy T.
    Poor me, never win owt!
  • 12-15-2007 4:09 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    You can add A-V.AUX (Audio from Video AUX) to the List.
  • 12-15-2007 5:20 AM In reply to
    caBur:
    I see Ignace has answered! The Wii is great fun! Have had one for a year now - works well with the AV9000. I bought the Wii RGB scart cable though I confess that I am not sure it was necessary!
  • 12-15-2007 6:16 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Thanks for all the replies! I'll see if i can give you some more information.
    My beo4 second button row contains SAT | AV | CD as you said.
    I've added V.AUX to my LIST so i can acces my wii channel. The sound works great on the TV.
    But when i tried to have the wii sound on the stero, i instinctivly tried RADIO -> AV -> and then pressing LIST until i got to V.AUX, and nothing happened.
    Just tell me if you need more info!
  • 12-15-2007 8:50 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Like i wrote in my previous post,
    you´ll have to add A - V.AUX to the list.
    V.AUX opens the Video Aux-port
    A-V.AUX opens the sound from the Video Aux-port
    (you will not need the AV-button in this case !)
    I have the same Beo4, and if i want the sound from V.AUX, i only have to press List once
    the Beo4 shows `A-V.AUX` , then i press `GO`
  • 12-15-2007 9:05 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
  • 12-15-2007 9:34 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Ok, i misunderstood you, sorry, missed the A-V :P
    However, i tried adding it and... I can't find any A-V.AUX!
    The only similair ones are V.AUX and A.AUX. Sorry if i still misunderstand you.
  • 12-15-2007 10:56 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    No problem Smile
    Could you check which software version your Beo4 has ?
    To check this : press MENU and GO simultaneously,
    the press List untill display shows SW:
    (my Beo4 shows SW: 5.00 )
  • 12-16-2007 10:28 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Just checked it. SW: 3.00
     What now? Indifferent
  • 12-16-2007 12:12 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Tough one, i'm slowly running out of options Smile
    Perhaps we could use a different approach.
    Instead of assigning the name "V.AUX" to switch to that socket,
    using another available name on that socket could solve the problem.
    For example V.TAPE2 instead of V.AUX to register the source in the Avant menu,
    adding V.TAPE2 to the list of Beo to have access to the source,
    and to have access to the sound : adding  A-V.TP2 to Beo4 list.
  • 12-16-2007 2:02 PM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Hmm... I THINK i got it. I tried changing it V.TAPE2 and adding it to the Beo4 list, but i still can't find any A-V.TP2.
  • 12-17-2007 7:38 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    I just realised that you have the AV button available (on my Beo4 it is in the List),
    Selecting the source is V.TAPE2.
    Selecting sound from that source : AV  + V.TAPE2
    If that doesn't work,
    perhaps you could use SAT to switch to source
    (audio: AV + SAT) ?
  • 12-17-2007 11:45 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Hmmm... V.TAPE2 seems to work exactly as V.AUX, i can't get any sound by pressing RADIO (or CD) -> AV -> LIST til i get to V.TAPE2 on the Beo4 (if that was what you were referring to). Feels like there's a somekind of selection button missing here.
    I tried the AV + SAT and that got the stereo's attention at least. But then i need guidance to link the SAT to V.AUX, which i don't have a clue how to do.
  • 12-17-2007 1:16 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Is the wii registered correctly in the Avant ?
    If the Avant doesn't "know" what is connected,
    it can't relay the audio.
    So, if you add for example V.TAPE2 to Beo4 list,
    make sure V.TAPE2 is also registered in the Avant sockets menu.
    Could you give an exact description of your setup ?
    - Avant (VCR or DVD)
    - which other components connected / to which socket(s)
    - which B&O audio
    - types of connection (between Avant and B&O audio)
    - Option setting of Avant and audio
    - how is the wii registered in the sockets menu of Avant  (as V.TAPE2 ?)
    Regarding missing button;
    your version of Beo4 is somewhat different (AV-button),
    but controlling B&O should be possible without any serious limitations.
  • 12-17-2007 2:02 PM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Ok, will answer as much as i can.
        *Since it's never had any DVD, i suppose it's... VCR
        *V.TAPE connected to its appropiate slot, antenna cabel connected,  WII connected through AV
    - which B&O audio
        *B&O Beosound Ouverture
        *AUX port to Avant
        *Don't really know what kind of info you want here.
        *As of now, it is through V.AUX. Tried V.TAPE2, no difference.
  • 12-17-2007 2:25 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Thanks, that gives a better overview.
    The Option setting i was referring to is a setting that tells the B&O components
    how to respond to remote control.
    As you have indicated that the Ouverture responds to AV + SAT,  it seems that Option setting is correct.
    What puzzles me is the connection between Avant and Ouverture.
    Both have Masterlink, so to connect them via an AUX cable would mean that you also use a converter
    to have the AUX-cable connect to Masterlink-cable.
    The wii, is it connected via a SCART-connector ?
    I get the impression that the problem is not in the relaying of sound,
    but getting sound into the Avant.
    I'm not familiar with the types of connections that wii uses,
    a quick Google-search shows video connection by component, composite and s-video,
    but these are video-connections, not audio.
  • 12-17-2007 3:50 PM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Hmmm, i think i gave you wrong info. They are apparantly connected through masterlink cable, my bad.
    Wii is connected through a scart connector (which was included) to the AV scart output.
  • 12-17-2007 5:11 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Is there sound from the Wii through the Avant speakers ?
    Does the Wii have some kind of setting for analog / digital audio / output ?
  • 12-17-2007 5:32 PM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Yes, the sound works great on the TV. No really advance soundsettings, just mono/stereo/surround.
    I just think it has something to do with settings, since i can't even make the sound system connect to either V.AUX or V.TAPE2 through AV. Somehow, when i start flipping through LIST, the AV command just cancels. Don't have any trouble connecting to SAT (which i don't even use) or anything like that.
  • 12-17-2007 6:06 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    In the Avant, is SAT selected somewhere ?
    Can you select "SAT" from the AV-socket-menu in Avant  ?
  • 12-18-2007 5:25 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    If you by socket-menu mean SOURCE, where i choose what type of device i have connected to the AV output, then... No, i can't select SAT.
  • 12-18-2007 6:41 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    What type of device can you select from AV  ?
  • 12-18-2007 11:41 AM In reply to
    • caBur
    • Not Ranked
    • Posts 12
    Non B&O V.TAPE2
    V.TAPE2
    S-VHS V.TAPE2
    CDV
    Decoder-2
    Special decoder
    V.AUX
  • 12-18-2007 11:58 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Perhaps if you select Decoder, you can use the normal TV command on Beo4
    Sound : AV + TV
    You would have to assign a channel-number to the program that shows the "decoder"
