Latest post 12-20-2007 5:13 PM by tyres. 14 replies.
Page 1 of 1 (15 items)
  • 12-12-2007 6:45 AM
    • tyres
    • Not Ranked
    • Joined on 12-12-2007
    • Posts 14
    Beogram 9500 to hifi amp
    My sister is donating her BeoGram 9500 turntable to my mother, and I'm donating my hifi amp, as my sister still requires her B&O amp. I've sorted out an adapter to connect the BeoGram 9500's 7-pin DIN connector to the amp's phono inputs. However my brother, who has an old B&O machine himself, has suggested there may be a problem because the non-B&W amp may not be sensitive enough to pick up the low signal from the 9500's pickup arm.
     Can somebody tell me if this is the case, and is there a workaround for it?
     Thanks.
    Colin
  • 12-12-2007 8:12 AM In reply to
    Re: Beogram 9500 to hifi amp
    Assuming you are talking about connecting to the phono input of an itegrated pre amp/amp combination then you should have no problem. The output from B&O cartridges is marginally lower than other moving magnet devices but should only require 1 click extra on the volume control.
    Regards Graham
  • 12-12-2007 1:18 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Thanks Graham. I wondered if the B&W amps might be a tad more sensitive than other amps. Thinking about it, my brother might have thought that my amp is more recent than it is, as I've been reading that newer amps don't have a phono pre-amp, as it's not expected that people will have turntables. However, I got my amp in the era when turntables were still the norm, so it is designed to take input from a turntable. Hopefully that means it's got a built-in pre-amp, although there's no mention of that in the manual. However, it does have dedicated 'phono' inputs at the back for a turntable (plus a 'ground' connection). So hopefully it will pan out ok.
     Cheers,
     Colin
  • 12-12-2007 1:43 PM In reply to
    That will be fine. Remember that you need an earth from the metal casing of the DIN plug.
  • 12-13-2007 4:18 AM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Peter,
     Yes, the adapter cable has an earth. That goes to the 'ground' connection on the amp does it? Is that to stop 'hum', or something else?
    Colin
  • 12-13-2007 4:44 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Correct on both counts ColinSmile
    Chris.
    PS - why tyres if you don't mind me askingConfused
  • 12-13-2007 4:15 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Used to be my nickname at school, because the kids heard my surname as 'Goodyear', rather than Goodier :-)))
     Apparently my nephew got the same thing. Kids, nothing if not predictable!
    Colin
  • 12-14-2007 3:32 AM In reply to
    • Medogsfat
    • Posts 4,045
    Big Smile
    Kids eh?
    Good nickname, I've definately had worse ones.Smile
    Chris.
  • 12-14-2007 12:10 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Chris,
     I just saw the reply you gave to a guy asking about connecting a Beogram 3300 (some while back) to a non B&W amp (i.e. DIN to phono). You suggested he might only be able to source a 5-pin DIN to phono adapter, e.g. from Maplins, and that he'd have to remove pins 1 and 7 from the Beogram's connector cable.
    Wish I'd known that trick, as I sourced a 7-pin DIN to phono adapter cable from FlashbackSales, at £20. It's a nice cable, though, very solidly put together, and with gold-plated connectors. There is a guy on eBay (Ireland) sells the 7-pin adapter cables as well  (maybe you know about him?), but I didn't really want to tangle with eBay. Reading some of the comments here in the 'eBay' section just confirms that you need to be very careful not to get ripped off on there!
    Still, I could have saved myself some cash going the 5-pin DIN route, as Maplins sell them for only £8. I should have got on here earlier!
     Colin
  • 12-14-2007 12:15 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Arghh, it wasn't some time back, was it? I was looking at the guy's join-date!
    Colin
  • 12-15-2007 1:28 PM In reply to
    • Medogsfat
    • Posts 4,045
    tyres:
    Colin
     Laughing
    We live and learn ColinBig Smile Look on the bright side though - you won't risk the chance of misplacing the datalink pins,
    Chris.
  • 12-15-2007 2:49 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Medogsfat:
    Or snapping then off as I did, when I gave my BG9000 to my Parents to use with their Beocenter 4000.EmbarrassedEmbarrassedEmbarrassed
    CraigSmile
  • 12-19-2007 3:20 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    My sister tells me she's remembered one of the reasons she's not using the Beogram 9500 is that she experienced quite a lot of hiss and crackle with it when playing her LPs. She doesn't think this s down to usage, as it didn't get that much usage (and she moved onto an B&O CD/tape unit thereafter. The Ouverture I think).
     Has anybody else experienced this? Sadly, in one respect, it may not matter, as my mother's hearing (she's getting the Beogram) is not the best, so she may not notice! Seems weird if it's had fairly low usage though. I suppose it could be the LPs of course.
    Colin
  • 12-20-2007 7:09 AM In reply to
    • Medogsfat
    • Posts 4,045
    Hard to say without hearing it 1st hand Colin.
    It could be the cartridge simply has a build up of fluff on it! Or the cartridge is worn or tracking weight set incorrectly - or as you mentioned, the LP's themselves.
    Chris.
  • 12-20-2007 5:13 PM In reply to
    • tyres
    • Not Ranked
    • Posts 14
    Well, I might get to hear it in action this Xmas, so I can make a judgement then. Cartridge wear seems unlikely if it's had light use, I'd have thought. Maybe my sister's ears are too sensitive ;-)
    Colin
