Latest post 12-18-2007 12:48 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 12-13-2007 7:38 PM
    Beogram 3300 adaptor for phone amp
    Hi
    My beomaster 3300 has gone belly up -when I try to select anything ie cd etc the light comes on then clicks off again, had this problem earlier in the year but it is back- and I may need to buy a new amp etc. I do not have the money for a new B&O system, but can afford about £200 for a new amp but it will need to be a Onkyo or something like that. My question is: is it possible to get an adaptor to connect the Beogram 3300 to a 'normal' amp?
    Confused
  • 12-14-2007 3:29 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 3300 adaptor for phone amp
    Hi & welcome to BeoworldSmile
    Yes,
           they are available from any decent electrical suppliers such as Maplin (in the UK). You will probably only be able to source a 5 pin DIN to phono cable which will require the removal of pins 1 & 7 from your Beogram output cable - these simply unscrew. Take care not to lose these as they carry the datalink information and will need replacing if/when you reconnect to a B&O beomaster to enable remote control functions.
    Have you thought about repairing your Beomaster rather than replacing it? I'm sure it would be cheaper.
    Chris.
  • 12-18-2007 5:34 AM In reply to
    Hi Medogfat
     Thanks for the reply and advice. I have taken your advice about getting it looked at and it is off to the engineers today, and I should know by tomorrow evening. I am rather nervous.
     Could I ask you another question? If the beomaster is fixed I still need to get a new CD player. I cannot find the one to go with this system. Given the age of my B&O it is worth while buying a good new one given the difference in technology. Up till now I have been using a cheap Sony because I was not sure if it was worth while buying a good new CD player.
    Yours
    Confused
  • 12-18-2007 12:48 PM In reply to
    • Medogsfat
    • Posts 4,045
    To be honest I would look out for a CD3300 on ebay, they do come along quite regularly (and well priced, normally less than £100) and I have yet to come across a non working one, they seem fairly bullet proof. The advantage of this is you'll be able to control it remotely using either a terminal 3300 or a beolink 1000.
    Any other CD player will be fine though but you'll probably need a phono/RCA > 5 pin DIN adaptor lead. You can even connect an IPOD or your PC using the AUX input via a jack > 5 pin DIN lead if you wish.
    Chris.
