Latest post 12-18-2007 4:56 AM by beoraki. 11 replies.
Page 1 of 1 (12 items)
  • 10-05-2007 4:08 AM
    DVD2
    Has anyone bought a DVD2 yet. I would love to know your thoughts..
    jazz
  • 10-05-2007 9:30 AM In reply to
    Re: DVD2
    It looks good.
    40 seconds to start up is far too long though. I understand that it has to "load" the hard drive... ,8,1 (some of your will remember this....lol) Why should you have to wait that long just to watch a dvd.
    Please let us know your thoughts when you start to make timer recordings with it..
    jazz
  • 10-05-2007 12:28 PM In reply to
    Re: DVD2
    Can you timer record from a satellite channel?
  • 10-05-2007 1:36 PM In reply to
    Re: DVD2
    There is no STB-controller in the DVD2
    eduard:
    now I have add the Sat reciver to the DVD-2 and now it becomes tricky, can not find out how to add this correctly.
    Same here. You need the HDR1/2 to get this working, for timer recording.
  • 10-05-2007 2:46 PM In reply to
    Re: DVD2
    Here is a workaround,
    Most set top boxes have 2 scarts, so you can connect one to the TV and one to the EXT1 socket of the DVD2.
    You can programme the DVD2 to record at a certain time from EXT1, and - separately- you can programme the set top box to tune to a channel at a certain time, using the set top box own scheduler.
    The Good:
    • It should work, and all with the Beo4
    The Bad
    • it is not elegant,
    • it require the 2 clocks to be in sync,
    • it does not "lock" the channel on the set top box, like another recorder would do,
    • it will not allow recording of the DVB module in the Beovision.
    p.
  • 10-05-2007 2:54 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: DVD2
    Beautiful design though, and the cabinet quality is stunning! Not too sure about the innards at the moment, but I don't have much experience with the DVD2. Didn't seem too user friendly when I first had a play, but I probably just need to play with it more!
    Overall though, beautifully finished, and absolutely looks the part.
     Weekly top artists:
  • 12-18-2007 4:01 AM In reply to
    Re: DVD2
    Hello,
    since 3 days I am also a owner of a DVD2.
    I have a BV6.22. The first scart is connected to a Beocord V8000 via a Samsung Digibox. In the connections menu (VTape + STB). The DVD2 is with the second scart connencted and as VAUX in the connections menu registered.
    If I look TV via the tuner of the DVD2 and want to record a programme always the V8000 starts and I cannot rrecord to the harddisk.
    How can this be fixed. Any ideas?
     Unsure
    Beoraki
  • 12-18-2007 4:56 AM In reply to
    Re: DVD2
    I tried it myself.......
    Hmm
