Latest post 12-19-2007 7:51 AM by TheMajor. 8 replies.
Page 1 of 1 (9 items)
  • 12-17-2007 10:41 AM
    Are these dead? 6000 repair estimate.
    Hey guys are these dead? How much is a repair going to cost me (ball park)? It looks like it is on the one speaker. What could have caused such serious damage?
     http://img105.imageshack.us/img105/2504/18524123aj7.jpg
    Beosystem 7000/6500- Beolab 4000 - Beosound 1 - A8 - Earset 3 - Beo4
  • 12-17-2007 11:17 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Are these dead? 6000 repair estimate.
    It's just a cone replacement, which is no way near enough to call for a replacement. Very cheap to repair and very routine operation for any engineer. I'd just talk to your local dealer...
     Weekly top artists:
  • 12-17-2007 7:49 PM In reply to
    Cool so no big deal at all then? Thank you.
  • 12-18-2007 10:52 AM In reply to
    bump
  • 12-18-2007 11:57 AM In reply to
    Alex is quite correct. Many 6000's exhibit degradation of the rubber surrounds at 10 years plus. I have replaced several.
    Might as well replace all 4. Cost is around £30 per driver plus labour. Tweeters should be checked at the same time as they are prone to fail with a burnt out voice coil. Their cost is about the same but the speakers are then as good as new.
    Might need some running in!!!Devil
    Regards Graham
  • 12-18-2007 10:19 PM In reply to
    Thanks, I found them for sale in Japan for a reasonable price and I am quite tempted as I always have loved the beolab 6000. If its not too expensive I may pick them up and have all of them replaced and get the tweeters checked too.
  • 12-19-2007 5:29 AM In reply to
    Omg, have to check my own BL6000. How do you remove the front cover?
  • 12-19-2007 5:53 AM In reply to
    Just slide them up about 20mm and lift them off.
    Regards Graham
  • 12-19-2007 7:51 AM In reply to
    I may pick them up and get them fixed up. Seems like it will be a bargain if they are cheap enough to get fixed.
