Latest post 12-26-2007 11:08 AM by Peter. 5 replies.
Page 1 of 1 (6 items)
  • 12-26-2007 8:39 AM
    Compiling a 5000/5500 Beosystem
    Hello!
    My original message was on bang-olufsen.com, but as adviced by Peter i'll post it here too.
    In a nutshell: i am trying set up a whole system (being Beomaster, Beocord, Beogram and Beogram CD, and preferably MCP too).
    In the original message i asked about possible conflicts and problems i may encounter when mixing 5000 and 5500 series components. I got a nice and informative reply from Peter, which is as follows:
     "The only big decision you have to make is the Beomaster. The Beomaster 5500, 6500 and 7000 are all pretty similar except the 5500 has rather more connections - it has RCA as well as DIN sockets - but it can have problems with the later Beolink 5000 and 7000 remotes unless modified. All of these Beomasters will work with the MCP5500 or 6500 and Beolink 1000/Beo4 though. Any of the 5000, 5500, 6500 and 7000 components units will work with these Beomasters as they all use Datalink which is the language used by B&O to connect component units.
    The Beomaster 5000 also uses Datalink and again will work with any of the tape decks, CD players and Beograms in this series.However it will not respond to the newer controllers but only the MCP5000 or Terminal 5000 as these remotes use different IR codes to the others.
    Choosing would seem to be easy - the 5500 is more flexible and uses the modern remote codes. Oh that it were so simple! The Beomaster 5000 is better built and the pre-amplifier is far superior. So is the display and you also have the benefit of controls on the drop down panel which the later models lack.
    It is however getting old - they all are - and they can all fail. The muting circuit on the 5500 is a common fault! For more information, come to the forum on Beoworld as you will get many opinions rather than just mine! "
    So, now i'd like have more of those opinions concerning these components, since i bet you people are a lot more experienced in this matter than i am. At the moment i have Beogram 5000, which is actually how i got introduced to this brand. So i lack all the other components. Getting a whole system at once is not out of the guestion, but so far i haven't found any with all the components, or they have been tagged with price close to 2000eur (being something like £1500). I see the beogram can easily be the most expensive single part of the system, so maybe it would be better to get all the other components part by part?
    When it comes to components in different series, i read that the most radical changes on Beosystem components are between 5000 and 5500 series while 5500, 6500 and 7000 components are pretty much the same, with minor changes of course. Am i right? As mentioned before the 5000 and 5500 Beomasters have their pros and cons. What about the other components? For example CD 50 and CD 5500.
    Phew, quite a post for a first one. :)
    Thank you very much for your time and answers!
  • 12-26-2007 9:33 AM In reply to
    Re: Compiling a 5000/5500 Beosystem
    It will probably be more cost effective to buy the rest of the system as one lump rather than as separates. For some strange reason, the 6500 systems don't seem to make as much money on ebay as they should!
    Just my considered opinion mind you, I am sure others will not agree!!
    Regards Graham
  • 12-26-2007 10:28 AM In reply to
    Yes, i considered that option too. But it seems that all the 6500 bunches on sale lack the Beogram and buying one separately seems to be quite expensive, bearing in mind that i already have one. :) Too bad it's of a diffrent color...How much it matters is just another opinion thing.
  • 12-26-2007 10:29 AM In reply to
    joeyboygolf:
    You are right about the 6500 system.
  • 12-26-2007 11:03 AM In reply to
    redfresnel:
    OK so look for a 5500 system and use your existing beogram. Or a 6500 system and get a £20 RIAA amplifier and use your existing beogram with that.
    There are so many options that it will depend on how much you want to spend and/or how long you want to wait.
    Regards Graham
  • 12-26-2007 11:08 AM In reply to
    The CD5500 is the best CD player that B&O made. The CD50 is pretty bomb proof as far as the laser is concerned but suffers from other faults.
    You should be able to get a Beocord 5500 for less than £50.
