I read the following in the products info for DVD2:
Multiregion fix.
As this machine is a repackaged Philips, it is easy to make multi region. Go to the Browse page with no DVD in the drive by pressing GO + 0 and enter the code. Don't wait too long between each number!
The code is GO 159 12 12 12 005 255 GO
Watch the digits on the player's LCD display as you key them in. When finished, go to standby and the next time you turn the player on it's ready.
I have a BeoVIsion 7-32 MKIII and I was wondering if the same "fix" and code can be used to make the DVD player in my BV7 region free?
Does anyone knows whether the same "fix" and code can be used the DVD player in my BV7? Or is there a similar "fix" and a different code I can apply to do the trick on my BV7?
Your help is much appreciated.
BR,
Lars.
