hi neil!
sounds good! that would mean, the other faulty component activated the protection circuit in the powersupply?
i guess line output transistor means one of the transistors in the horizontal output circuit on pcb 10, perhaps tr5 or tr 8 (BU508)?
as you see, i´ve got the service manual... plus soldering skills and some experience in diy audioequipment...ok brought two capstandrives of vx vcrs back to life, but that´s it in the field of tv...  so repairing the tv would be more like trial and error, especially, as i haven´t got a oscilloscope for checking the components. but i think, i´ll give it a try ( of course, i´m fully aware of the high voltages in the tv and i won´t do anything riscfull at all!!!)
tim jarman from beocentral guessed exactly the same as you did about line output stage, so as two experienced experts are of the same opinion, that´s definitly the right direction to go!
thanks a lot for your help!
jens
