Latest post 12-06-2007 11:19 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 12-06-2007 11:14 AM
    Masterlink cable connections ?
    Hi can anyone help ??
     Im just trying to run a masterlink cable from my beovision 4 system box around the lounge to a junction splitter box then off in two ways to my BS 9000 and thn slipt one up into the loft to me beo PC box.
     Problem I have is I have 100meters of masterlink cable in order to get the stuff around the house but stupidly I have lost the Masterlink cable connection diagram so im unsure which way the individual coloured cables go into the little adapter plug ??
     I have normal ML cables from Lifestyle AV but looking through the individual cable colours are differnt (must be an aftermarket cable) so I cannot copy the layout.
    Many thanks
    Scott
  • 12-06-2007 11:19 AM In reply to
    Re: Masterlink cable connections ?
    I am sure that Matt or Lee at Lifestyle will be able to supply a duplicate diagram. Suggest you give them a ring.
    Regards Graham
