Sounds as though you have Dolby then! On the label though there should be a section with ACC and some letters after it. Mine has STB DS PIP on it. This means STB controller, Dolby Surround and Picture in Picture modules are fitted. I actually have a DTS module as well but this is on another sticker as it was added later.
Yours may have either DS or more likely AC3
