Latest post 11-24-2007 12:34 PM by bwaje. 2 replies.
Page 1 of 1 (3 items)
  • 10-01-2007 6:10 AM
    • pfly
    • Not Ranked
    • Joined on 10-01-2007
    • Posts 1
    Beogram 1200 speed issues
    Ok, so the problem is that my turntable starts reeeeeaaaally slowly. When I push start-button, first it seems like the platter wouldn't turn at all, then it starts to gain revs really slow. after some 3-5 minutes it spins as it should (well almost, with pitch turned all the way up). The "gears" (small copper/brass cone in the end of motor's shaft and large rubberwheel the cone touches) are transferring the power nice and tidy. While TT is gaining speed, if I try to help it by spinning the record by hand, it won't help, the speed falls to where it was before I touched it. To me it seems like the motor would slowly gain it's right operating voltage, like it would be charging itself. When I flip the record or change the record, next time I push start, it will gain the right speed MUCH faster, but still a bit slowly... But if I let it be for some hours then it'll be way too slow again, like some condenser's would lose voltage or something...
    http://www.danny.mcnulty.btinternet.co.uk/audio.html
    It seems like this guy would be having the same problem.
  • 10-02-2007 7:08 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1200 speed issues
    Welcome to Beoworld !
    Your Beogram is in need of cleaning and lubrication of the motor bearings. It's a 1-phase AC motor and it needs to be taken apart to do it right. We've seen this a couple of times before, do a search on these fora and you'll find more info.
    It's a lovely deck and worth the trouble.
  • 11-24-2007 12:34 PM In reply to
    • bwaje
    • Not Ranked
    • Joined on 11-22-2007
    • Paris - France
    • Posts 38
    Hi Dillen I searched but found nothing relevant for lubrication or bearings; the search is rather disapointing because of the duplicated posts.
    b&otien
