Latest post 11-21-2007 9:17 AM by Frank Rizzo. 19 replies.
Page 1 of 1 (20 items)
  • 11-06-2007 1:10 AM
    10disc CD changer...
    Does anyone know about the 10 disc CD changer built for BnO by sony i believe..???
     What equipmnt if functions with, etc??
    THanks
  • 11-06-2007 1:38 AM In reply to
    • Jez
    • Top 500 Contributor
    • Joined on 06-13-2007
    • Posts 150
    Re: 10disc CD changer...
    It wasn't built by Sony. It was the original prototype model (non functional) built by David Lewis, he works with models when designing new products. It looks just like the BeoSound 9000 only longer. Very cool but obviously would have been less feasible. Have seen it in person, very cool.
  • 11-06-2007 1:43 AM In reply to
    Hi Jez.... thanks...though actually the "box" i'm talking about looks like it goes in a car system....its a changer and is labeled BnO.......any ideas??
    Thanks...k
  • 11-06-2007 1:45 AM In reply to
    I think the original poster is referring to the CMM-10 which was a US model designed to work with systems like the 7000 system. It is indeed based on a Sony car CD changer with a clever B&O Datalink interface. Seem to crop up in the US from time to time. I have seen one in the UK. It needs to go in a cupboard because it looks just like a Sony CD changer! Laughing
  • 11-06-2007 1:50 AM In reply to
    Hi Peter,
    Would that work with my Beocenter 9500.....????
    THere was a cheap buy it now price on Ebay USA.....so i just picked it up...i'm guessing that Sony could re-furb it if necessary...??
    Any possibility of getting a manual on this thing??
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=220168902018&rd=1
    THanks...k
  • 11-06-2007 2:57 AM In reply to
    Yes, it will work with a 9500. It acts as if it is Tape 2 and responds to normal Datalink commands. I believe it takes a 12V supply. It is labelled as a B&O so I am sure Sony will disclaim any involvement! I dare say Tim Jarman, who has interests both in B&O and Sony would be delighted to help! I am afraid that I don't think I have this manual. Would probably be worth asking on Beolist, the Yahoo group as they are mainly US based.
  • 11-06-2007 4:19 AM In reply to
    Peter = B&O encyclopedia guru Cool
    I think all BeoWorlders owe a thanks to you Peter. Your B&O knowledge continuously amazes me, and guess what?! I have also just seen your November quiz - could you have wanted to make it any more complex for us non-mathematical minded?! Laughing
    I hope you will not be offended if my answer is way off the correct figure!
  • 11-06-2007 10:29 AM In reply to
    Thanks Peter....!!!   I agree Henry.....Peter has got the answers...let's not leave out Keith either....I'm always in appreciation of their help...
    I'll try to get on Beolist...do you have a link??
  • 11-06-2007 10:39 AM In reply to
    It is in Yahoo groups. At work at present so don't have link. Been going for ages!
  • 11-06-2007 1:16 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    No wonder it was so cheap - the seller isn't including the separate power supply.  Apparently he realizes it might not be complete, which is why he's offering a 7-day return on it.  I have the player/power supply but haven't hooked it up to my Beosystem 6500 yet.
  • 11-06-2007 1:38 PM In reply to
    Hi...thanks for posting on this...do you have an extra power supply that I could buy..??  or can you reference me any model numbers to get one??
    Any info on this would be really appreciated...!! ie...the manual...anything...
    Thanks...Keith
  • 11-06-2007 2:00 PM In reply to
    • mediabobny
    • Posts 336
    I don't have an extra power supply and they certainly wouldn't appear on eBay as a solo item very often.  Someplace I have the instruction manual tho - if you'll give me your email I'll scan it and send it to you.   I'll also email you a photo of the power supply showing the part number.
  • 11-06-2007 2:36 PM In reply to
    I have found the set up guide! I'll put it on site !
  • 11-06-2007 2:44 PM In reply to
    Not very detailed! But here it is!
  • 11-06-2007 3:11 PM In reply to
    Thanks Mediabob and Peter...
     I see I need the converter....type 5103 converter....
     If anyone has one for sale....
    THanks..k
  • 11-06-2007 4:08 PM In reply to
    I think the converter is the clever bit. You'll not find one in the UK. US eBay would be the best bet.
  • 11-08-2007 5:14 AM In reply to
    • TEL
    • Joined on 04-16-2007
    • Berks U K
    • Posts 92
    I have a U.S. brochure from some years ago which shows the cd changer inside the F1000 furniture
    The brochure is the one on the right.
    TEL
  • 11-09-2007 1:27 AM In reply to
    Does anyone have pics of this "type 5103 " converter???   Thanks !!
  • 11-18-2007 2:47 AM In reply to
    UPDATE. I got my CMM-10 (Just the 10 cd box) with blue 13 pin DIN lead.from an Ebay auction.......Secondly, our own Mediaboyny has helped me locate an AC adapter necessary to make the CD box work...(Thanks !!), I should soon be getting the control box soon which will allow me to interface this into my TAPE 2 of a BC 9500...
     QUESTION...does anyone have any more manuals, info, pamphlets ....other than the 3 page info that Peter has put on the site..(thanks Peter)...
    Thanks..>!!
  • 11-21-2007 9:17 AM In reply to
    Hi Peter....how would I get in touch with Tim Jarman for any repairs on this sony build CD changer, etc??  THanks, K
