Latest post 11-19-2007 6:19 AM by symmes. 1 replies.
Page 1 of 1 (2 items)
  • 11-15-2007 5:05 PM
    • atm
    • Not Ranked
    • Joined on 11-15-2007
    • Posts 6
    sudden issues with N.RADIO?
    Hi all!
     My PC2 set-up has been working perfectly for two years, but suddenly I cannot listen to almost any N.RADIO stations at all. Beoport refuses to connect to all swedish ones and works basically with randomly selected foreign ones. I find this really strange for two reasons
    a) I have not touched my B&O system, nor my PC - so did it suddently start failing
    b) I'm still connecting to a few stations so it's not the network
    Any advice would be welcome
    thanks //anders
    // 4 x BL8000 // BV3 // PC2
  • 11-19-2007 6:19 AM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Re: sudden issues with N.RADIO?
    Hello Anders.  It sounds as if you have reverted back to the sampling of NRADIO that comes with a basic BeoPlayer installation, rather than BeoPort.  I would recommend starting over with BeoPort software.  Also, it tends to work better when you completely uninstall the old version.  Hope this helps.
    Ray
