Latest post 12-10-2007 4:24 PM by Tom. 10 replies.
Page 1 of 1 (11 items)
  • 12-09-2007 2:48 PM
    • gofer
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 27
    How do I clean my BL8000
    Hi
    I would welcome any advice on polishing the aluminium pipes of my BL8000's, recently purchased pre-owned. Whilst they are in perfect condition, the pipes appear a  little misty, perhaps smoke or maybe something else.
    Any ideas?
  • 12-09-2007 3:14 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: How do I clean my BL8000
    Normally a mild detergent with a soft cloth is a good place to start.
    Chris.
  • 12-09-2007 3:30 PM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Or alternatively, baby wipes! They are superb at lifting grime, tobacco residue etc and are perfectly safe to use on plastic and metal parts. After using wipe off with a soft cloth or kitchen towel. Perfect results every time!  It does make you wonder though about the poor baby's bottoms.....
    Cheers
    Nigel
  • 12-09-2007 3:38 PM In reply to
    • Medogsfat
    • Posts 4,045
    Ah yes - I forgot about about baby wipes Nigel.
    Brilliant things they areSmile
    Chris.
  • 12-09-2007 5:30 PM In reply to
    You can also use Window spray it easily removes tobacco. the ALU surfaces is like glass so no problem in using it.
  • 12-09-2007 6:16 PM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    In the shop we used only a wrung out chamois leather.  The imitation ones are fine also.  Just give the pipes a good wipe, and lightly wipe the speaker fabric - this will remove any dust or lint.  Then polish the pipes using a soft cloth.
     Chamois leathers are great to wipe the screens on Beovisions - especially when anti reflex coated.  Do this in the morning when the TV is cold.  Lightly clean the screen and polish to a high shine with a soft clean cloth. NO CLEANING PRODUCTS.
  • 12-09-2007 7:29 PM In reply to
    • Tom
    • Top 25 Contributor
    • Luxembourg
    • Posts 3,175
    I use those eyeglass cleaners you can get in any supermarket to clean mine. They remove fingerprints very well...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 12-10-2007 7:54 AM In reply to
    • Medogsfat
    • Posts 4,045
    tom:
    I want to know what you use on your tuba Tom? - now THAT'S properly shineyIdeaStick out tongue
    Chris.
  • 12-10-2007 10:02 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    Medogsfat:
    tom:
    Chris.
    Laughing
    I only use a soft cloth on my tuba, but not often enough. The closer you get to it, the more finger prints and other traces can be seen. I don't treat it as good as my B&O.
  • 12-10-2007 4:11 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    And yer head, Tom?Wink
    Andy T.
    Poor me, never win owt!
  • 12-10-2007 4:24 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    No comment Smile
