Hi all
What is the best resolution to set on a mac mini for connecting to a BV 3-32?
I tried all the standard resolutions (800x600, 1024x 768) but I guess there are better settings.
Any ideas?
800 x 640 would be the best. Anything higher and you won't see a thing! Anything lower and there will be no display space! Are you using the Mac as a media centre?
Weekly top artists:
Thx,
yes I am using the mac mini as media centre.
