Latest post 10-17-2007 5:13 AM by nobby. 2 replies.
Page 1 of 1 (3 items)
  • 10-17-2007 3:50 AM
    MX 5500 Integration....
    Quick question....i've got a BC 9500 in my bedroom....and ive got a armoir....to put a TV inside......is a MX 5500 a good integration with the Datalink with the BC 9500?????
    Can I take it off the stand and put it in the armoir??  Is that advisable??
    Thanks,k
  • 10-17-2007 4:04 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: MX 5500 Integration....
    Should work perfect. No problems to remove the stand.
    Just make sure there´s good ventilation in the armoir.
    Don´t forget to check the options on the MX and BC.
  • 10-17-2007 5:13 AM In reply to
    Yes, the point abot ventilation cannot be emphasised enough ... at best the TV will run hotter than it should and artificially age the components ... at worst it could overheat and self-destruct.
     Neil
