Latest post 10-11-2007 4:54 PM by rotel1111. 3 replies.
Page 1 of 1 (4 items)
  • 10-11-2007 3:43 PM
    Cover to B & O Century
    How shall I change my textile cover on my B & O Century?
    Filed under:
  • 10-11-2007 4:33 PM In reply to
    Re: Cover to B & O Century
    I think you should better try to find new covers.
    I found new ones 1 year ago for my 13 years old Century on ebay.
    It seems to be very hard to attach and to correctly tend the fabric.
  • 10-11-2007 4:51 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    bertone:
    You should still be able to order new frets from your dealer.  They are held on by 4 x small screws (2 at the edge of each side).
    Not worth the effort trying to re-cover them, and i doubt it will look too good either!
    Lee
    Smile
  • 10-11-2007 4:54 PM In reply to
    Take off your Century from the wall or the stand, turn back and turn off the screws. Then change the covers. That is it Smile
