I would like to know if anyone has made a lead to run a B&W PV1 sub using the PL from a BL6000.
Can this be done?
I dont mind if I have to switch the sub on manually , I just want the sound!!!
Thanks in advance
FOR EVERYTHING ELSE......THERES B&O
Just use a regular Din- RCA converter cable with all 4 Rca connectors. The 2 connectors that normally is carrying the "in" signal is carrying the R&L "out" signal from your Powerlink socket. I use this to get sound from my Ouverture to a Rega amp powering my B&W P5 Speakers.
If you want the sub to turn on when using your B&O system, just get a TV-powersaving plug (have no idea of the english word, I use one of these to turn on the Rega amp, http://webshop.nesa.dk/projects/nesa/shop/cmsdoc.nsf/content/nesp73whg4?opendocument )
br
Chr.
HI,
the DIN-to-RCA connector i used with a Magnat active sub:
The PV1 has auto sense on / stand by, so it switches on/off with the rest of your setup.Very nice sub by the way ! 500 W ICE power !
Ignace www.iggyswebsite.com
