Ok, so I've read up on the Serenata including the 2 reviews posted here and their associated follow-up up Q&As. To me, the Serenata is one feature short of being a very desirable product. Simply put, if it had a line input, I'd be sold. What I'd love to see is a high quality ultraportable speaker that I could use with any source I chose. If the Serenata had a line input on its dock, this would suffice, but alas I know that this probably isn't something that could be added to the finished product. I'd love to see it in a next gen version or perhaps as a spinoff if B&O decided to include such a speaker with the BeoSound 6's eventual replacement or, better yet, even as a standalone ultraportable speaker product. I've gone ahead and submitted this suggestion to B&O, but I wonder what the folks here think of the idea. Here are a few points to consider:
- First, as far as I can tell, no one is offering a high quality ultraportable speaker. I emphasize ultraportable to convey my desire for something the size of the Serenata or smaller. Given the meteoric rise of the iPod as a popular consumer product, MP3 speakers now come in all shapes and sizes. While there are some great dock speaker units out there (I just picked up B&W's Zeppelin and it's the best dedicated iPod speaker dock I've heard to date), all of them are way too big for true on the go use. If it's small enough and light enough to be carried around in your pocket, it's more likely to be taken with you. I have a JBL On Tour unit that is pretty good, but is a little too big ffor teh kind of use I'm thinking of and does also suffer from some distortion issues. Every ultraportable speaker smaller than that I've tried winds up sounding bad, especially at higher volumes where distortion is a fact of life for speakers this small. As an example, I decided to give Altec Lansing's new iM207 Orbit ultraportable speaker. It plays pretty loud for a speaker of its size, but I've found that volumes above about 40% from my iPod Classic sound distorted when playing more aggresive music (rock, R&B, etc). There's a void in this space for a small speaker that can reproduce well without distortion and I'd love to see it filed.
- I'm not deluded into thinking that the output quality from such a small speaker could ever match what you get from larger systems. I don't expect something that can overwhelm a room from a volume aspect nor do I expect the objective sound quality to equal what you get from larger speakers. I just want something that can play decently loud without distortion while offering pretty good sound quality. From what I'm reading, it sounds like the Serenata produces exactly that. I'd just like the ability to get the same result using any source I choose.
- Why not just use the Serenata as is? There are a number of issues here. For one, I like the iPod. I've owned or extensively tested MP3 players from Creative, Sansa, MS, Philips, Sony, etc. None of them do as good a job of combining a portable interface with an easy to use desktop application as Apple does. I'm sure the Serenata is a nice MP3 player, but It's not going to better the iPod. Secondly, 4GB just isn't enough for me. I've learned to manage playlists on my 8GB iPhone, but I wouldn't want to have to manage half that amount of space. I also have a 160GB Classic that I keep my entire music/video/photo library on. Thirdly, the Serenata doesn't support certain kinds of sources. Consider using such a speaker with your laptop for streaming audio, movies, etc. the Serenata's output is probably better than just about any built-in laptop speaker available. Basically, I want to be able to use whatever device suits me and be able to pair it with a top quality ultraportable speaker.
- I know that this is easier said than done. For one, I'd guess that an input couldn't be added to the current Serenata. From what I've read, it looks like the Serenata works by applying internal EQ to all music it plays back. The challenge for B&O was that physical space limitation of small speakers is the culprit behind distortion at higher volume levels. They have apparently solved this issue via smart EQ. They know what the speaker's limitation is and they design the EQ to modify the music such that the output doesn't contain distortion, regardless of volume. With music files on the Serenata's flash memory, this can all be done in the digital domain. For an external source though, you're going to need A to D conversion of the incoming signal. That would likely require additional hardware and software that may not be present on teh current design. So, we're talking about a future hardware version or even a separate product altogether.
- Is there really a market for this? I think so and I kind of think B&O does to. Remember, they designed the Serenata first and foremost as a "mobile music system" that differentiates itself by having a quality speaker in a tiny package. My thought is to expand this idea by giving users to flexibility to get the same result using any source they choose.
- Even if it was just a standalone ultrportable speaker (no phone, no MP3 player), it won't be cheap, but that's ok. For one, no one expects a B&O design to be inexpensive. For another, we're not just talking about a small speaker. It would be a "smart" speaker containing the EQ, battery, input(s), ICE amplifier, etc. It would also be in the stylish design that you expect from B&O. This wold all come at a price, but would be well worth it to finally have a quality ultraportable speaker. Keep in mind that I'm not opposed to a design that would include an MP3 player and/or phone functionality - I just want the input more than anything else and I'd be willling to take it even if it came with other features that I didn't really need.
So what does everyone else think? Am I crazy or is there a market for something like this?
Jeff
