Latest post 10-04-2007 12:22 PM by Peter. 5 replies.
Page 1 of 1 (6 items)
  • 10-04-2007 4:56 AM
    Old BeoSystem 5000 terminal remote control availability & compatibility
    Hello there!
    The 1980s BeoSystem 5000 installed in my new home has insufficient hand-held terminal remote controller devices and I wondered how easy it would be to obtain extras?  I see that there's an identical looking device for a BeoSystem 3000 on ebay at the moment and wondered if anybody knows whether the 3000 & 5000 remotes are compatible for the simple on/off/mute/select functions?
    Chris T.
  • 10-04-2007 5:06 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Old BeoSystem 5000 terminal remote control availability & compatibility
    Hi CTunafish & welcome to beoworldSmile
    No - the terminals 3000 & 5000 work on different frequencies and are therefore unable to control anything other than their dedicated systems. Terminal 5000's & MCP5000's do appear on ebay regularly though.
    Chris.
  • 10-04-2007 6:09 AM In reply to
    Not sure is the answer . I might be able to find out later this evening though as I have a code converter which works for at least the 5000. I'll see what it says about the 3000. Chris is probably correct though.
  • 10-04-2007 7:56 AM In reply to
    Chris, thanks very much indeed for the rapid & informed response. I'll keep my eyes peeled for the correct type. What an excellent resource this is!  Much appreciated.
    Chris T.
  • 10-04-2007 8:05 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    I would definitely get at least one MCP5000 - they look the biz and I'm sure they control more functions than the Terminal 5000!
  • 10-04-2007 12:22 PM In reply to
    Different codes - Chris was right - of course! I have a special code converter which allows you to use a Beolink 1000 to control a variety of older types of equipment - Beomaster 6000/8000, Beocenter7000 etc and Beomaster 5000. All use different codes.
