After moving, I set up my stereo, removed my MMC4 from its box, and replaced it on the tone arm of my Beogram RX. I adjusted the counterweight to what seemed right, but didn't bother to recalibrate and check everything before trying to play a record. That was a mistake. The tone arm skidded off of the record onto the aluminum, and once I had adjusted it properly, it was sickeningly distorted. I found Soundsmith's website, and followed their instructions to visually inspect, and though I saw nothing out of place, when I tried the cartridge again, it didn't even play distorted- just a hum.
So, one way or another, it's broken, and I'm in the market for a Soundsmith. I can't really afford a SMMC3, but then, I can't really afford a SMMC4 right now either, and that's not going to stop me!
Still, I'd like to know, does anyone have any experience with both? Is the difference noticable? If I'm used to a MMC4, and was happy with it, is it worth spending $80 just for a solid diamond stylus?
