My Beocord 7000 plays and records wonderfully.
After about two hours of playing (or just being on), there is suddenly a loud screeching noise coming from the deck.
Playing does not seem to be affected and the only way to get rid of the sound is to shut the unit down.
Even then the sound continues for a few seconds afterwards
All functiosn seem to work properly even when the screeching starts.
Regards
Andrew
