Alessandro,
What you have here is the safety circuit being enabled to protect the TV. This happens on these sets when one of the following occurs:-
- One of the power supply voltages is missing, over voltage or overloaded.
- A bus error has occurred with data between the various IC's
- There is an error in the EEPROM
A B&O engineer can put the TV into service mode by using a jumper and it will show him the error which has occured. With this information an assessment can be made of the likely fault and therefore cost to fix it.
I would have it fixed if it was previously working perfectly.
