Latest post 09-25-2007 9:01 PM by TheTinman. 6 replies.
Page 1 of 1 (7 items)
  • 09-24-2007 12:41 PM
    • joeaksa
    • Not Ranked
    • Joined on 09-24-2007
    • USA
    • Posts 7
    Beovision MX5000 roll control and sound level issues
    I have a Beovision MX5000 that has worked fine for many years now. In the last couple of months it has starting losing its roll control, and at times the picture will roll without stopping for a while. It does this for a while, then the normal picture returns.
    I assume that there is a "roll adjustment" somewhere on the television or in the electronic menu for the set, but I cannot find my book for the set anywhere and cannot find one to view on the internet.
    Also while on the subject of the television I have noticed that the sound level that I get at max seems to be coming lower, in other words when the set was new I could blast myself out of the room but now at max its fine but no where near what it used to be. This is using the Beo4 or Beo 1000 remotes (yes, I have a lot of B&O products) and no difference in the sound output. Any ideas what could be causing the television to be losing output in this area?
     TIA,
     Joe
    Phoenix Arizona
  • 09-24-2007 9:06 PM In reply to
    Re: Beovision MX5000 roll control and sound level issues
    Hi Joe,
    These problems are caused by bad electrolytic capacitors. The solution is simple but tedious: Replace ALL black electrolytic capacitors of Rubycon brand in the set . They will eventually all fail. I have written a repair guide for the MX-5000 and it is on the Connoisseur Club if you can do the repair yourself!  If you are not familiar with electronics, go to a good repair shop!
    Good luck!
    Jean
  • 09-24-2007 10:05 PM In reply to
    • joeaksa
    • Not Ranked
    • USA
    • Posts 7
    Jean,
    Thanks for the reply and how much of a hassle is it? I built a Heathkit television as a kid (and it actually worked) so know what a soldering iron is used for!
    Is this for the roll control or low sound issue?
    Thx,
    Joe
  • 09-24-2007 10:41 PM In reply to
    Replacing the capacitors will fix BOTH issues, and likely improve the picture as well.
    I am a technician by trade and go through hundreds of capacitors a month.  Just be careful not to overheat the circuit board while soldering/desoldering.
    Marc
  • 09-25-2007 1:25 PM In reply to
    • joeaksa
    • Not Ranked
    • USA
    • Posts 7
    Marc,
    Thanks and how difficult is it to get to the capacitors that need replacing? Do not mind taking it a ways apart but if they are on the bottom of a stacked circuit board that takes hours to get to and there are hundreds of them to replace the "fun meter" goes downhill at that point.
     Any suggestions on where to buy these parts?
    Thx,
    Joe
  • 09-25-2007 7:39 PM In reply to
    Dear Joe,
    First get the service manual and then the repair guide I have written about replacing capacitors on the MX-5000. Both are on the Connoisseur Club of this site.
    About 50 to 100 capacitors scattered over three PC boards may have to be replaced. So have a spare TV ready when you will do the repair as it may took time. All the boards are accessible but require the chassis to be removed and connectors removed. This is a long repair, but "doable" as I done it myself two years ago.
    Good luck!
     Jean
  • 09-25-2007 9:01 PM In reply to
    Joe, since you are also in the US, you can get capacitors from digikey or mouser electronics.  Another good one is suburban electronics.  (NOT their URL, google it)  I buy bags of caps from them.  They stock a LOT of parts and the prices are good.
    A B&O is worth the time and effort to properly re-cap.  Just take your time.  I do loads of this for a living.  It's not so bad.
    Marc
