Hi all
Today i got an answer from Bang & Olufsen support, that subtitles IS supported for most formats. A technician had testet it, but could not make it work with IDX & Vobsub subtitle format.
I did not get any technical instructions, so I will try some tests ... will post back if any luck :-)
Hola from Dinamarca,
Kent
