Latest post 09-11-2007 6:34 PM by Frank Rizzo. 2 replies.
Page 1 of 1 (3 items)
  • 09-11-2007 12:08 AM
    7 volts in Powerlink...running LED's
    For certain decor reasons...i'm wanting to install some cobalt blue LED's behind each of my powered speakers and behind my beosound 9000.......
    At first I was just going to install a blue ropelight and run a separate switch....BUT...
    Then, I was thinking, could I use the 7volts used to switch on the speakers on and take that off the Powerlink and run LED's....(which take almost no power)....
    Thanks,
    K
  • 09-11-2007 5:59 PM In reply to
    Re: 7 volts in Powerlink...running LED's
    Don't think it's a good idea, a blue LED use 30mA if it's a small one, mush more then a speaker does.
  • 09-11-2007 6:34 PM In reply to
    Thanks Stig...
