Latest post 09-11-2007 10:04 AM by puasho. 2 replies.
Page 1 of 1 (3 items)
  • 09-11-2007 5:47 AM
    • puasho
    • Not Ranked
    • Joined on 09-11-2007
    • Posts 2
    Any new FW for BS4?
    Hi folkSmile
    I'd like to know if , as far as you know, there is any new Fiemware  around for the BS4. I thougt I heard of an upgrade regarding the SD card compliance (as far as 4 GB...or so) .an some minor faults fixed...
    I'm still waiting for a revisited Loudness curve, but I think I'll not see it in this life.Angry
    Thanks in advance
    L
  • 09-11-2007 5:54 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: Any new FW for BS4?
    Yes, the latest SW sorted out the compatibility problems with BeoSound 2 & 3 (SD cards). This was released in January/February 2007.
    Roger
  • 09-11-2007 10:04 AM In reply to
    • puasho
    • Not Ranked
    • Posts 2
    Thanks a lot Roger Smile
