Hello all,
 I have some questions regarding the above setup.
1.  I have a VGA to 3 BNC cable - can I use this?  If so, how?  I am currently using a 25 ft VGA cable to the PC input with a visible reduction in image quality, and I would like to use the PC input for my PC.
2.  Are closed captioning or P-in-P designed to work when viewing a hi-def source?
3.  My Beolab 4500's turn off when the Beosystem 1 is turned off, but then they turn back on for about 10 more seconds.  Has anyone else experienced this?  Is this a setup code problem (I am using code 560)?
Thanks in advance for your help
Matt
									    BS1, BV4, MX5k, VX5k, BS9k, Beolab Penta, 4.5k, 4k, 3.5k, 3k, Beo4, Beolink 7k, 5k, 1k, Beoport etc
