Right, here goes-----
1 Add V.SETUP to your list
2 Press Radio
3 Leave the room and press TV and then list until V.SETUP appears
4 Press GO, it should then say TUNE
5 Return to the room were your Beomaster 7000 is
6 Press up or down til you get the fequency you're looking for
7 Press list until STORE appears
8 Press GO 17 Go (presuming you want to store your new station as 17
Bit long-winded, but it works
Hope this helps.
Andy T.
