Latest post 11-13-2007 11:32 AM by Len. 9 replies.
Page 1 of 1 (10 items)
  • 11-04-2007 5:41 AM
    • Len
    • Not Ranked
    • Joined on 11-04-2007
    • Posts 5
    Output levels
    I have a Beocentre 2200 that I wish to use to transfer music from records to CDs using either a computer or video recorder.
    There is an output jack at the front marked "Headphones"  Which I assume is stereo.  I need to know what the output level is and whether it comes from a pre-amplifier.    Can anyone please help?       Len.
  • 11-04-2007 6:33 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Output levels
    Hi Len,
    Welcome to BeoWorld Smile
    If you want line-level for recording to external device,
    i guess you could use the socket for the extra tape recorder.
    (called TAPE COPY)
  • 11-04-2007 6:40 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: Output levels
     The User Guide
  • 11-04-2007 6:55 AM In reply to
    • Len
    • Not Ranked
    • Posts 5
    Re: Output levels
    Hello Ignace,   Many thanks for your reply, I think the "tape copy" output is called a Din connector? I do not know what the connections are but perhaps they are standard. I may be able to get a lead suitable for connection to the computer. I have mislaid the original manual, which is why I was asking about output levels as I don't want to damage the computer. Regards, Len.
  • 11-04-2007 7:02 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Re: Output levels
    Is that connector a circular one with 5 or 7 pins ?
    You can use a DIN-to-RCA-connector, like this one f.e.,
    available at electronics store.
    I used to use this kind of connector to get line-level signal (of a TAPE-socket) to an active (amplified) subwoofer).
  • 11-04-2007 6:14 PM In reply to
    Re: Output levels
    you can use the headphone socket as well, you just need to set the volume, to all most max then the output is the same as line level..
  • 11-05-2007 10:50 AM In reply to
    • Len
    • Not Ranked
    • Posts 5
    Re: Output levels
    Hello again Ignace,  Many thanks for your info.  Yes it is a 5 pin socket and I believe the connections are 1&4; 3&5 but don't know which is left and right.     I have found a suitable plug in the Maplin catalogue, I now need to sort out the computer end.
    What is standard level? is it 1v p-p?    Regards, Len.
  • 11-11-2007 7:37 AM In reply to
    • Len
    • Not Ranked
    • Posts 5
    Re: Output levels
    Hello again Ignace,  I was unable to get a DIN to RCA lead. But did get a 5 pin DIN plug and I have a RCA to RCA lead.
    I plan to cut the RCA lead and solder to the DIN plug thus making my own lead.    My problem is, that I do not know the connections, ie, left signal and ground, and right signal and ground.  Please can you or anyone else help. Many thanks, Len.
  • 11-11-2007 8:52 AM In reply to
    • Alex
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Output levels
    The top diagram is the one you want.
    Ignore pins 6 and 7, they're not needed at all, and your plug won't have them. They're only used on special 'Datalink' connections, all the other connections are the same as a standard DIN plug.
     Weekly top artists:
  • 11-13-2007 11:32 AM In reply to
    • Len
    • Not Ranked
    • Posts 5
    Re: Output levels
    Hello Alex, Many thanks for your kind assistance, I should now be able to proceed with my project. Regards, Len.
