1st March February 2012
Latest post 11-22-2008 4:48 PM by soundproof. 25 replies.
11-21-2008 5:00 AM
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
BL5´s and higend non B&o cd player
Hi all I am getting a bit tired of my BS3000, feeling i am not getting enough value from my lab 5´s through analoge. I want to by a non- B&O cd player with digital out and connect it to my lab5´s. Has anyone got this setup functioning "out of the box"? Read something about the nessesarity of custom cables etc. What about volume control? I would like to control everything through the cdplayer and not using a b&o remote. Would be happy if anyone had the oppotunity to help me. Have allready searched the forum and found a couple of older posts, however couldnt quite understand everything i read. Thanks in advance Ehlerz
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Re: BL5´s and higend non B&o cd player
Any CD player with a S/PDIF out signal, coaxial, will work. However you will need to control the Lab 5's with your Beo4 remote. I actually thought of having a high-end CD player to use with my Lab5's, but in the end, the BS 9000 is such a good value for money, and spending thousands of euros on a CD player to be used simply as a transport is perhaps not the best of ideas. The digital bits is the same from all transports IMHO.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
It is a good idea IMO, and you can still use the BS3000 for casual listening/radio, and have a CD-transport for serious listening. I think Peter uses a Beogram CD 5500 together with his BL5, try and ask him. best regards Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
ChrDH: It is a good idea IMO, and you can still use the BS3000 for casual listening/radio, and have a CD-transport for serious listening. I think Peter uses a Beogram CD 5500 together with his BL5, try and ask him. best regards Christian
I'm sure he would if actually had BL5's
stefan
- 200 miles from Struer
- Posts 1,733
I had a Beogram CD 7000 connected to my BL5s. A really great machine. To control the player and the BL5s an MCL 2AV should work. Connect the CD player to the CD input of the MCL 2AV, Powerlink to BL5 and spdif from CD 7000 to BL5. This solution is not really expensive and it`s possible to connect more devices to the extra kit and control by Beo4. Stefan
ChrDH
- Denmark
- Posts 493
Puncher: ChrDH: It is a good idea IMO, and you can still use the BS3000 for casual listening/radio, and have a CD-transport for serious listening. I think Peter uses a Beogram CD 5500 together with his BL5, try and ask him. best regards Christian
Ok, then it must be someone else, i just tought it was Peter...
Puncher
- Posts 9,588
ChrDH: Puncher: ChrDH: It is a good idea IMO, and you can still use the BS3000 for casual listening/radio, and have a CD-transport for serious listening. I think Peter uses a Beogram CD 5500 together with his BL5, try and ask him. best regards Christian
You're partly right - it was discussed in a thread here, at the time Peter bought a CD5500 after auditioning several non-B&O CD players. It was commented upon that, should he eventually get BL5's, he could use the digital output of the CD5500 to drive them. He still needs a bit of a push to go that extra mile though
soundproof
- Posts 2,340
I can strongly recommend the Cambridge Azur 840C. It has 2 X toslink and coax s/pdif IN, and coax s/pdif OUT to your BL5s. This means you can connect a variety of units (computer, stand-alone DAC, digital cable from STB to 840C, etc.) I use it in pass-through mode, just sending along the digital signal from my other units, as well as from whatever CD is in the tray - but you can also experiment with its sophisticated upsampling in analog and digital. The same processors are in CD-players costing ten times as much. I control it with a universal remote, which also controls my BL5s and all the various units attached to the 840C. Or you can go all B&O, with a Beosystem 7000, which has coax s/pdif out. Just get the Beomaster and Beogram CD7000. You can control everything with a Beo4. They come up regularly on various net sites - here's one:
wonderfulelectric
- Joined on 06-27-2007
- Posts 302
Get this. It's affordable and very well known for its novel belt drive technology. http://www.cec-web.co.jp/products/cdplayer/tl51x/tl51x_e.html But why would you want to get a normal transport when you can get a hard disk server that is very close to displacing high end cd transports in the near future? Such as one of these. http://www.zerooneaudio.com/ http://www.novaphysicsgroup.com/ If you are still unsatisfied after getting a new transport. Get a PSaudio power premier. It regenerates your power and don;t forget to get quality power cords too. They make a world of difference. The effect of the power premier is subtle but it improves every single area of sound performance, you really only miss it after it you remove it from the system.
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Yes, using the S/PDIF output from a high-end CD transport directly to the Beolab 5 will give you the best possible sound, as the signal will be in the digital domain all the way through the system, with no digital to analogue conversion to add errors to your music. I would agree with previous comments that Beosound 9000 is actually good value for money as possibly the only credible high quality multi-CD transport with a digital output - and it looks great too! If you want to go from a non-B&O CD player to the 'Lab 5's via S/PDIF, you will need:- 1) One 75 Ohm co-axial cable for each speaker - these can be "daisy-chained" so that the first speaker feeds the second speaker and so on. 2) One Sync cable (3.5mm stereo TRS plug at each end) for each pair of speakers so that they both keep to the same volume level. 3) A Beo 4 or Beo 5 remote control to power the speakers on and control the volume. You could consider a universal remote that has a 455kHz output for B&O compatibility (there are other threads elsewhere on the forum about this). I'm not sure if I dare say this, but I disagree with B&O's official advice on the best cabling for the Beolab 5 when used in S/PDIF mode. The Beolab 5 user manual states "Use ordinary phono cables (RCA) to connect the loudspeakers to your system". This would be correct for analogue audio, which has a nominal bandwidth of 20kHz, putting it in the "low frequency region" of 75 Ohm cables, ie. they typically have a high impedance at these frequencies. However, S/PDIF digital signals can have a typical bandwidth of between 48kHz and 192kHz (with "pulse edge" transients at much higher frequencies), which is in the "transition region" for most 75 Ohm cables, making them well suited and consistent performers for transmitting digital signals with minimal loss and distortion. And in my book, that is the main aim. I have always been pleased with the results of 75 Ohm co-axial cables for S/PDIF use over ordinary audio cables, so I now recommend the use of 75 Ohm cables for Beolab 5. I would welcome views from others who have tried these - please let me know what you think! Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Peter
- Joined on 02-12-2007
- Posts 9,572
Have thought about it a few times but have decided to go in exactly the opposite way and get my Beolab 5000 system upgraded by Frede at Classic Audio.
Alex
- Bath & Cardiff, UK
- Posts 2,990
The BeoSystem 6500/7000 would be the cheapest way of getting a 'true B&O system', but TBH I think you would prefer a BeoSound 9000. There is no difference in sound when using a BeoSound 9000 vs a super-duper high-end transport along with BeoLab 5s, as the BeoLab 5s handle all of the signal processing etc...
Either that or a BeoCenter 2...
Weekly top artists:
Beobird
- Joined on 04-19-2007
- Netherlands
- Posts 506
If you really want a better performance you should buy a high-end cd-player and connect it with the normal anolog din cables to the lab 5's. If you connect such a player through spdif it won't use the DAC's from the high-end player. You need a pre-amp to control the volume. At the end you will have the best performance, but you should invest at a couple of thousand euro's. Getting a Beogram cd 7000 is also a good option, it costs less and it performs very good.
We Can't Get Enough B&O Stuff...
Puncher
- Posts 9,588
Beobird: If you really want a better performance you should buy a high-end cd-player and connect it with the normal anolog din cables to the lab 5's. If you connect such a player through spdif it won't use the DAC's from the high-end player. You need a pre-amp to control the volume. At the end you will have the best performance, but you should invest at a couple of thousand euro's. Getting a Beogram cd 7000 is also a good option, it costs less and it performs very good.
Is this true?? If you use an analogue output from an expensive CD player the first thing that happens is that it's digitised again when it enters the BL5. That makes two unnecessary conversions! Surely the spdif connection gives the best possible sound as it bypasses both unneeded conversion processes. The BM/CD 6500/7000 would probably be the best option as you could then use them with other B&O stuff. (The CD5500 has the digital output but doesn't have the more modern powerlink connections)
soundproof
- Posts 2,340
This can be discussed back and forth. The processing inside the BL5s is extremely sophisticated, with digital and analog upsampling through processors from Analog Devices, prior to amplification and with a variety of signal correction processes -- I doubt there are (m)any cd-players on the market that deliver a similar result - which means that one should focus on getting a coax s/pdif signal to the speakers if your choice is a BL5. My Cambridge Audio 840C has similar processing to that found inside the dCS Puccini, but I'm still using the coax s/pdif instead of the analog upsampled from these. Have tried both. You might want to experiment though, as I did, just to be satsified. I have also tried using other digital cabling than that supplied by B&O - could be my ears, didn't hear a difference. I have grown to become very skeptical of claims as to differences with digital cabling. But if the manufacturer of the transport specifies 75Ohm coax, then one should use that.
bayerische
- Helsinki, Finland
- Posts 3,593
Beobird:If you really want a better performance you should buy a high-end cd-player and connect it with the normal anolog din cables to the lab 5's. If you connect such a player through spdif it won't use the DAC's from the high-end player. You need a pre-amp to control the volume. At the end you will have the best performance, but you should invest at a couple of thousand euro's. Getting a Beogram cd 7000 is also a good option, it costs less and it performs very good.
I thought the Beolab 5 re-samples the signal anyways, since it has digital cross-overs? ... ? Then Its no idea to have a very expensive CD player. I had a Pathos Endorphin previous to my BS9000, and I was thinking of saving it to use with the Lab5's, since the look of the CD player was somewhat same as the Beolab5's look. But I didn't see any point to have a 7000e + CD player and have the signal redone by the lab5's. And having such a expensive transport is just a waste of money IMHO.
-Andreas
Alex
- Posts 2,990
Connecting BeoLab 5s via digital is definitely the way to go!
Bear in mind that any signal which goes through the BeoLab 5 will be passing through the software inside them. Connecting a CD player via Analogue is just adding in two extra conversion stages, and for every conversion stage, there is a (usually) small, but noticeable loss in quality.
Weekly top artists:
Beobird
- Netherlands
- Posts 506
bayerische: Beobird:If you really want a better performance you should buy a high-end cd-player and connect it with the normal anolog din cables to the lab 5's. If you connect such a player through spdif it won't use the DAC's from the high-end player. You need a pre-amp to control the volume. At the end you will have the best performance, but you should invest at a couple of thousand euro's. Getting a Beogram cd 7000 is also a good option, it costs less and it performs very good.
I thought the Beolab 5 re-samples the signal anyways, since it has digital cross-overs? ... ? Then Its no idea to have a very expensive CD player. I had a Pathos Endorphin previous to my BS9000, and I was thinking of saving it to use with the Lab5's, since the look of the CD player was somewhat same as the Beolab5's look. But I didn't see any point to have a 7000e + CD player and have the signal redone by the lab5's. And having such a expensive transport is just a waste of money IMHO. Didn't know that, but then it's a waste of money to buy a high-end cd-player
bayerische
- Helsinki, Finland
- Posts 3,593
Beobird: bayerische: Beobird:If you really want a better performance you should buy a high-end cd-player and connect it with the normal anolog din cables to the lab 5's. If you connect such a player through spdif it won't use the DAC's from the high-end player. You need a pre-amp to control the volume. At the end you will have the best performance, but you should invest at a couple of thousand euro's. Getting a Beogram cd 7000 is also a good option, it costs less and it performs very good.
Yes, it is a waste of money to have a High-end CD player, but I don't see any negative sides to this. The whole thing just glorifies the Beolab 5's even more. Since they sound much better than my previous high-end system, which was 20% more expensive than my current.
-Andreas
soundproof
- Posts 2,340
Not necessarily - depends upon what that high-end CD-player does. The signal you are listening to, stored on the CD, has been resampled numerous times during production and mixing, before ending up as a 16bit/44.1kHz Redbook signal with Solomon-Reed sample correction in-built on a CD. The subsequent playback chain can degrade this signal, but what happened before it was stored on the disk doesn't concern us. The CD acts as a medium for transfer, with full signal integrity; think of the BL5s in the same way.
Here's a recap of my BL5 experiences - might be useful. Dave Moulton was kind enough to state that "soundproof seems to have a good handle on the BL5s" - it's from this thread. http://forum.beoworld.org/forums/permalink/137989/137353/ShowThread.aspx#137353 Do note that if your transport upsamples digital-to-analog to, for instance, 32/384 - and you send that analog signal to the BL5s, then you won't experience any degrading of the signal through BL5's processing - the integrity of what you hear is preserved. (Have tried this with both a dCS Puccini and an Cambridge Azur 840C). If you want to perform full frequency band DSP and room-correction,
you can still do that with a pair of BL5s at the end of the chain -
it's not the automatic room calibration that makes these speakers
superior. At any rate, it only affects the range from 12Hz to 400Hz. The uniqueness of these speakers is due to a number of reasons. 1.
The acoustic lenses. To get anything similar, you have to look at
designs from Bolzano-Villetri or MBL, and you're then looking at a
tripling of your budget to get similar sound (not better sound,
similar.) 2. The four-way design, with the unique bass delivery
and the homogeneity of dispersion of mid and top. Yesterday, I had an
electrical engineer and loudspeaker co-developer visit for a first
listen to BeoLab 5s. He was astonished at the power response, the
flatness of the frequency response and at the stability of the
extremely detailed soundstage. These speakers deliver with a
calibrated Sound Pressure Level within 0,25dB through the range - there
aren't any other speakers on the market that are close to that. And
they are upgradeable, with both software and firmware, should the need
present itself. The unique performance is a function of the
dispersion characteristic and the very sophisticated timing and
feedback processing with active monitoring of individual drivers, to
ensure a precision that is quite unique when it comes to delivery. As
I've mentioned you'll find that Meridian is doing some sophisticated
work with their top of the range active speakers, but you can do the
same with BL5 with a variety of DSP options. Check out DEQX for one
alternative. 3. If you want more sophisticated DSP, then just buy
it, and connect it between your source and the speakers. You still get
the benefit of what the BL5s are the only ones capable of. 4.
There is one area where the BL5s may need modification. We're beginning
to see sources in resolutions well in excess of CD (16bit/44.1kHz) BL5s
upsample analog or digital signals they receive to 24/96, and then pass
that on for processing and final 32/192kHz DAC conversion before
amplification. I may not be using them right, but I've not been able to
get them to accept bitstreams in excess of 24/96 without suddenly
getting dropouts. This means that you'll have to use them in analog
mode - that is, feed them a converted analog signal. I've been testing
- and this works out quite well - though I can imagine that a future
version of the BL5s might be given the ability to natively process
higher resolutions, up to 24/192kHz or even higher. 5. Since 98%
of the world's speakers are built according to principles that were in
use in the 1920s, I think the BL5s still have a way to go before we're
ready to consign them to the scrapheap! 6. The founder of 2L,
who is working with full resolution recording of music, and whose
Blu-ray release Divertimenti is creating a furore in the audiophile
world, came for a listen to my BL5s, and he was quite pleased with what
he heard. He had a recommendation, as he suspected that something could
be gained by adding a fifth driver - a supertweeter working above 20kHz
- to the speakers. It was his experience that such supertweeters
assisted the stability of the high frequencies in the audible range (up
to 20kHz) and that this modification might provide icing on the cake
when playing high-resolution files through the speakers. (See this
month's Stereophile for their initial reaction to Divertimenti.) It's
quite a nice test to have someone who has recorded the music, and mixed
it, come and listen to it on a pair of speakers ... (One comment that
may surprise some was that he would like them to be even sharper in the
top, above 6000Hz, in order to be true. You often hear people
"complain" that BL5s are too sharp.) I'm certain we'll see
modifications in speaker designs and in how we control the frequencies
produced by speakers, now that DSP is becoming more accessible and
better understood -- while storage space is cheaper and studios are
equipping themselves for working in the highest possible resolutions --
but I'm also certain that my BL5s will stay in my listening rooms for
many years to come.
soundproof
- Posts 2,340
koning:What about the "old" ones.......Do you think sounproof they will be up-gradeble in the future.
As an owner of a pair of "old ones" I'd like to answer yes, but I wonder. It would be a substantial job, I suspect. Maybe Dave Moulton can offer an opinion. Whether you need to is another matter. There have been extensive studies where high-resolution playback has been compared to cd-resolution -- and where hundreds of test persons have not been able to distinguish significantly between the two. The BL5s handle 24bit/96kHz, and I would think that will suffice. Also worth noting that if you do the upsampling "outside" the speakers, they will convey that result without coloring or degrading it. Which means I'm not worrying about this ... Too bad B&O didn't focus on the tremendous advantage that this technology offered, from 2003 onwards, instead of messing about with mp3-players and mobile phones!
soundproof
- Posts 2,340
koning:What about the software in the beolab 5,can they improve that also or will that not give any sound improvements.
That's upgradeable through replacement of the ROM-chip in each -- maybe someone here knows whether there have been any such upgrades worth looking into, and what they are?
beoberlin
- Berlin
- Posts 163
Have you thought about one of Classé´s Delta series? Imho they go at least from a design related point of view quite well together. Regards, beoberlin
