Latest post 11-02-2007 4:21 AM by Beowulf. 2 replies.
Page 1 of 1 (3 items)
  • 11-01-2007 9:55 PM
    How do you take the handset apart on a Beocom 2400?
    My phone is acting up and I'm pretty sure it's a broken wire coming into the handset.  It works great unless you stretch it or wiggle at the handset.  I slid the plastic piece of just below the wire but that didn't reveal very much.
    Thanks,
    Alex
    Filed under:
  • 11-02-2007 4:06 AM In reply to
    Re: How do you take the handset apart on a Beocom 2400?
    The straight answer is you don't - B&O would regard the handset as a replacable unit! However a little heat and some cautious probing should allow you to prise the two halves apart. It has been done before but be prepared to buy a new handset!
  • 11-02-2007 4:21 AM In reply to
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    I replaced mine only 15 pounds from B&O
    Dave
    Beowulf
