Latest post 08-07-2007 11:43 AM by beopaul. 4 replies.
Page 1 of 1 (5 items)
  • 08-06-2007 12:36 PM
    • joynsyde
    • Top 500 Contributor
    • Joined on 07-09-2007
    • Midwest, U.S.A.
    • Posts 130
    BeoLab 7-1
    Could you hook up a BeoLab 7-1 or 7-2 to a non-B&O audio source? I understand there's no line-in option, making powering on an issue. Is there a way to get around that?
    Thanks in advance,
    Aj
    ...my two cents ~AJ
  • 08-06-2007 12:57 PM In reply to
    Re: BeoLab 7-1
    Well, I don't own a BL7-1 or /2 -- but my BL3s connect nicely through a Powerlink to RCA adapter supplied by B&O, and I would be surprised if you couldn't use a similar one with these speakers. The only issue being that you want to be certain you get a stereo-connection.
    I have separate channel wires now, with a Powerlink plug in one end and RCA in the other. You would want a Powerlink plug with two strands of wire going out, to separate R and L plugs.
  • 08-06-2007 2:14 PM In reply to
    Re: BeoLab 7-1
    Yes it cut be done, but you need to make your own cable, from a normal Power Link. Green and brown is L/R, yellow has to be supplied with +5V to power speaker on. and shield and blue to ground.
  • 08-07-2007 11:19 AM In reply to
    • joynsyde
    • Midwest, U.S.A.
    • Posts 130
    Re: BeoLab 7-1
    Well, darn.
    Too bad that's the only way to do it.  I don't have time (or a workbench! Sad)to solder anymore these days; I was hoping there was something simpler.  Guess I'll have to go for a pair of separate speakers instead.
    Thanks anyway!
    ...my two cents ~AJ
  • 08-07-2007 11:43 AM In reply to
    Re: BeoLab 7-1
    I'm currently running my BeoLab 2 with an non-B&O surround box.  A B&O store (US) ordered the adapter for me.  I'll have to double-check, but I think you plug an RCA connector into one end and your powerlink cable to the Lab2 on the other end.  It also has a wall-wart transformer to provide the ON signal to keep the Lab2 awake.  I don't remember, but it might take two RCA plugs.  If so, it should work with a stereo speaker like the 7-1.  I'll double-check this tonight.
    -- Paul
