Now DVD2 is almost arriving in Holland, I wanna do a comparison with the HDR2: which (dis)/advantages does it have ?
In Holland the DVD2 will be cheaper than the HDR2!
http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
Go for the HDR2 thats a proper B&O.
If you want a DVD recorder bay one you like and get a lintronic to it instead...
nothing good to say about the DVD2
The Stig,
What do you mean by: "nothing good to say about the DVD2"?
And howcome the HDR2 is €140,- more expensive (in Holland) than the DVD2; the latter seems more complex/more hardware?
Peter: I have Sky+ as well as VCRs and a DVD/HDD recorder. I use Sky+ as it integrates perfectly with my B&O and is completely idiot proof!
You say that, but I'm sure Rupert Murdoch can use his own products.
Weekly top artists:
Rombeek: The Stig,What do you mean by: "nothing good to say about the DVD2"?And howcome the HDR2 is €140,- more expensive (in Holland) than the DVD2; the latter seems more complex/more hardware?
HDR2 is made by B&O
DVD2 is a Phillips in another case and you can only timer program it if your placed in GB
I believe it's actually a Samsung model, instead of a Philips.
Alex: Peter: I have Sky+ as well as VCRs and a DVD/HDD recorder. I use Sky+ as it integrates perfectly with my B&O and is completely idiot proof!You say that, but I'm sure Rupert Murdoch can use his own products.
I bet he wishes he was as clever as you
it's this one with HDMI like the US version
The Stig - ver. 1.2:it's this one with HDMI like the US version
You're right, it is a Philips, I was wrong. However, it's a 7300, as Peter proved in a thread a while back. All the connections are in exactly the same place, and the OSD seems very very similar.
