Latest post 05-31-2008 1:51 PM by Razlaw. 6 replies.
Page 1 of 1 (7 items)
  • 05-31-2008 2:50 AM
    BeoVision 9 built to last with built-in robot
  • 05-31-2008 3:39 AM In reply to
    Re: BeoVision 9 built to last with built-in robot
    As a non technical person,I have wondered about the accuracy/usefulness of this.
    Given the apparent short length of the arm,and it's restricted arc of travel,will the accuracy of it's calibration not be influenced by the on screen image at the time of the sensor's activation?
    Or is a known test chart generated?
  • 05-31-2008 4:12 AM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    When I ordered my BV9, my dealer told me that ACM device and D10 panel will be included, as well as 4.17 software (I was hoping for 4.20 with 24 fps support, but it seems it is not available for the time being).
    I haven't seen the ACM at work, as my dealer's BV9 was an older version.
    It seems that a test chart is displayed, in order to enable the ACM to make the adjustments. So the rest of the scren is turned to black.
    I agree that the arm's length seems to be rather short and I wonder how the camera will check the bottom of the screen.
    When I shall recieve my new TV, I'll make a movie of the process.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 05-31-2008 8:46 AM In reply to
    I understand the concern with the arm being short, but this is how ISF calibrations are performed (i.e. in one localized area). Essentially the aging of the phosphor is uniform enough to generalize a single area over the entire panel. There would not, for example, be a big blob in the lower corner where green is bleaching out. Then consider that the chromatic adjustments can't be localized anyway, so it's the average value you're looking for, and not the extreme.
    It's also important to remember that the calibration performed by the built-in camera is something that owners of high-end video systems have been paying to have performed already. In fact, the cost in the US ranges around $1,000 per visit. Bang & Olufsen didn't invent this technique, but we are the first and only company to build it into the package. We've gone ahead and assumed that someone purchasing the most expensive televisions in the world will likely want to maintain the picture quality that drew them to the screen in the first place and saved them tremendous service cost or picture degradation over the life of the system.
    Hope this helps make sense of the camera.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 05-31-2008 8:54 AM In reply to
    So now the picture on the new 9 and new 4 should be identical, correct?
    My wife and I are trying to decide what to replace our Avant with, 4, 7, or 9.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 05-31-2008 8:56 AM In reply to
    When I click on the link in the first post here I see nothing about the 9?
  • 05-31-2008 1:51 PM In reply to
    Just tried it again, this time it worked and I did get the Beovision 9 article.
