1st March February 2012
Latest post 02-12-2012 11:16 AM by hm231168. 11 replies.
B&Ola
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.22.65/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Joined on 04-16-2007
- Posts 302
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Re: Programmering af Beosystem 7000?
Beolink 5000 fungerar bra!
/Ola
Søren Hammer
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.66.55/avatar.jpg)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Beolink 1000 skal virke, den bruger samme koder som MCP7000 og Beolink 7000. Beo4 og Audio Terminal kan også bruges
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Tillquist
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.36.32/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 05-26-2007
- Denmark
- Posts 211
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
Beolink 1000 kan kun styre BeoSystem men ikke timer programmer det.Kun BeoLink 5000 og BeoLink 7000 kan timer programmer BeoSystem 7000. Jeg tror også at en Master Control Panel 6500 kan, men ved det ikke.
My Bang & Olufsen....
- BeoCenter 2 DAB/DVD mk.II
- BeoVision 7-40 DVD mk.III
- BeoLab Penta mk.III
- BeoLab 4000 icepower
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beo 4 mk.I & mk.III
- Beocom 6000
- A8 Earphones
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Master Control Panel 5500 og 6500 er nøjagtigt magen til Master Control Panel 7000
Tjntjn
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 03-05-2011
- Posts 10
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Beomaster control er vist ikke det samme som Beolink.
Hvordan søger man bla efter fm stationer og får adgang til ekstra funktioner på cd'en, når man kun har en Beolink 1000.
Beolink 5000 og 7000 er noget dyre på brugt markedet. Vil en controller 5500/6500 kunne bruges i stedet? Har de også 2 vejs IR?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Ved søgning af FM-stationer på Beolink 1000 bruges <>, tryk store > Store og den kanal, du vil gemme stationen. Ved CD-afspilning trykkes det nummer som skal høres, der kan skippes med <> samt pil op og pil ned.
Master Control Panel 5500/6500/7000 har alle to-vejs kommunikation, sammen med Beolink 5000 og Beolink 7000.
Soren
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.31.18/avatar.jpg)
- Joined on 05-04-2007
- Kolding Denmark
- Posts 56
Jeg har både Beolink 5000 Beolink 7000 og en MCP5500 til mit 7000 de kan alle timer programere anlægget Men gør det ikke i samme "register" det vil sige at en programmereing der er lavet med Beolink 5000/7000 kan ikke ændres eller slettes på MCP5500/6500 og omvendt kan et MCP program ikke ændres/slettes på Beolink 5000/7000.
Søren
Tjntjn
- Posts 10
Kan man bruge en Master Control Panel 5000 til et Beosystem 7000?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Tjntjn:
Nej, det kan man ikke da MCP5000 benytter sig af de ældre "Link 82" koder. Den ældste Master control panel du kan bruge er 5500, samt 6500 og 7000, Beolink 1000, 4, 5000 og 7000.
jornjak
- Joined on 05-12-2011
- Posts 6
Hej, har en Master Control Panel 5500. Kan købes for 500 danske kroner.
hm231168
- Joined on 02-12-2012
- Posts 1
Hejsa,
har du stadig din MCP5500?
Mvh
Henrik
Page 1 of 1 (12 items)
