1st March February 2012
Latest post 02-20-2008 10:47 PM by camshaft. 38 replies.
01-06-2008 9:09 PM
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
A Solitary Record?
Lone-Lee, i am so Lone-Lee!!   If anyone ever gets a screen grab of just themself and less guests online - there's a pair of A8 Earphones to the first one! Now there's a challenge to keep you awake! Lee
Dillen
- Copenhagen / Denmark
- Posts 5,008
Superb ! Maybe if you stopped singing ?  Martin
9 LEE
- Moderator - UK
- Posts 5,223
Yes.. Welcome Home to England!  Hopefully it was insured - but still a complete pain. What network are you on? I have a Nokia handset that works with Orange you can borrow if you're stuck for a phone. Lee
GuyHui
- Joined on 03-17-2007
- Posts 1,560
That's really nice of you Lee. Alex, iPhone is really cool especially when it will have a better APN, but I am looking forward to get the vers.2.  By the way, the new LG Viewty is very tempting, I have seen one in the flesh this WE but I am dying to buy the phone. All stores there, are out of stocks (SFR, Orange, etc.)  Cheers, Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
The Plumber
- Joined on 04-16-2007
- Plymouth UK
- Posts 669
Brilliant idea Lee, if only i knew how to take a screen shot
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands A tradesman uses his hands and his head A craftsman uses his hands, his head and his heart
9 LEE
- Moderator - UK
- Posts 5,223
I had no idea until Van showed me! With the risk of annoying everyone, and typing this from under a table with a crash helmet on - do you have a Mac? If so, i can help you - if not i can't.. - but someone else can i'm sure! All you need after that is the ability to be awake until stupid-o'clock, and you could be a pair of A8's better off !!  Lee
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
I can help you with the screen shot if you have a Windows PC.
The Plumber
- Plymouth UK
- Posts 669
I have Mac
The Plumber
- Plymouth UK
- Posts 669
OK i can now take a grab shot, but it is the wrong type of file to post. I will work it out. BTW, i already have some A8s, im more interested on how this screen shot and posting a screen shot works, but saying that, when im on call, i can be found on Beoworld at stupid times, so you never know.
9 LEE
- Moderator - UK
- Posts 5,223
It saves as a tiff, then i drag it into CS2 and save it as a jpg. Not sure if i'm doing that wrong mind you - but it works! Uploading to the forum with Safari is a waste of time. If i want to do anything it's always Firefox. Lee
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
Thank you for your very kind offer Lee, but I am in fact using an iPhone at the moment until I get a new Serene tomorrow morning from my dealer. I will insure it this time! Have just had my Red Bull to keep me up until silly o'clock and hope that you all fall asleep nice and early! Forgive me for any nonsense posting in the meantime. Guy, I have had LGs in the past and would seriously not recommend buying one. They have recently had some appealing phones for sale, but my advice is to resist the temptation and buy a good quality phone, from the likes of Nokia, Samsung and Sony Ericson. All my LGs were bought on its design and went wrong under 6 months of use. No big problem I thought, they're still under warranty, but in each case, LG found something wrong with the phone to tell me that its fault was not covered under its warranty. Awful after sales and awful phone. Will NEVER buy one again. Beware.
Peter
- Joined on 02-12-2007
- Posts 9,572
9 LEE:It saves as a tiff, then i drag it into CS2 and save it as a jpg. Not sure if i'm doing that wrong mind you - but it works! Uploading to the forum with Safari is a waste of time. If i want to do anything it's always Firefox. Lee
You don't need to do that. Save it as a tiff. Then just click on it and it will open in Preview. You can then save it as a jpg. Takes seconds!
Alex
- Bath & Cardiff, UK
- Posts 2,990
You can change the default screen capture file type in OS X, just type defaults write com.apple.screencapture type jpg into Terminal. Obviously, you can change what goes at the end. PNG is the best, as you'll end up with no image quality loss, but a very small filesize (as long as there isn't a massive variation of colours in the image).
In OS X, Command + Shift + 4 will allow you to draw a box in which the screenshot is taken, although if you press Space immediately after the initial key combination, you can take an image of individual elements on the screen, Windows, Icons etc...
Command + Shift + 3 will take a screenshot of the entire screen.
Weekly top artists:
9 LEE
- Moderator - UK
- Posts 5,223
Nope - it's ONE person only.. YOU - and less than 19 guests to win the prize.
GuyHui
- Posts 1,560
Peter:You don't need to do that. Save it as a tiff. Then just click on it and it will open in Preview. You can then save it as a jpg. Takes seconds!
Hi Peter, But concerning the size (in octets), will you get a lighter picture ? I use the Photoshop's Save for Web option for saving Web images, because I want to keep as small in file size as possible. Guy
9 LEE
- Moderator - UK
- Posts 5,223
I could send you some fake A8's in response to that!   Lee
