Latest post 02-02-2012 2:29 PM by stotty1111. 1 replies.
Page 1 of 1 (2 items)
  • 02-01-2012 7:10 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Assigning buttons on Beo4(with joystick)
    I have a BV6-26, which I have now setup to receive TNT(French Freeview) - minor tweaks needed, recent stormy weather turned the aerial on its pole!
    The tv reacts to pressing the DTV button ie it boots up TNT, I recall in the dim and distant reference to possibly assigning this function to the defunct TV button so that UK Sky can be used with the DTV button ie to ease use of the Beo4 without needing to scroll thro' the functions using the list button - I'm basically an idle s*d!
    Tell me or point me someone please.
    Salut a la cold Finistere(panic here with the froggies there was a light dusting of snow and the traffic almost ground to a halt)
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 02-02-2012 2:29 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Assigning buttons on Beo4(with joystick)
    Bumppppp.......
    No one then
    Or can the tv be set up to do this, if so how?
    Tony
