Latest post 01-26-2012 4:04 AM by riis. 9 replies.
Page 1 of 1 (10 items)
  • 01-22-2012 5:12 AM
    • riis
    • Top 500 Contributor
    • Joined on 05-01-2007
    • Denmark
    • Posts 152
    CD 50 no sound
    After having spent several hours repairing my beloved CD 50 for the usual tray problems everything works fine except for one thing. It doesn't say a sound..............The tray opens and closes smoothly, the laser goes back and forth in order to find the right tracks, but unfortunately no sound.
    I have checked all the wires, but I can't figure out what's wrong...................
    /riis
  • 01-23-2012 3:05 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 no sound
    Hasn't anybody got an idea what might be wrong. Is the laser ok if it finds all the tracks? Can I have broken a wire while fiddleing with the laser unit?
    /riis
  • 01-23-2012 12:43 PM In reply to
    Re: CD 50 no sound
    What are you using the machine with,and how is it connected?
    Does the display on the front indicate that the disc is playing normally?
    Nick
  • 01-23-2012 3:16 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 no sound
    solderon29:
    Nick
    Yes, the display on the front indicates that the disc is playing normally. It is connected to a Beomaster 5500.
    When everything was working correctly, I think that the cd player started playing automatically when the tray was pushed in. This is not so now. Now I have to push the play button before the player starts. But maybe I'm wrong.
    I have tested all the wires with a tester, and none of them seem to be broken.
  • 01-23-2012 4:00 PM In reply to
    Re: CD 50 no sound
    From Beocentral
    Beogram CD 50
    29th August 2008
    The fault was no sound, although the disc was clearly being played as it turned normally and the time counter was reading correctly. The muting transistors were turned on all the time however, the cause was C351 in the muting circuit, it had dried up and gone open circuit. [Beogram CD 50]
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-24-2012 2:55 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 no sound
    Søren Mexico:
    From Beocentral
    Beogram CD 50
    29th August 2008
    I have replaced the C351 which is a 10 uF 16v capacitor with a 10 uF 50v capacitor. From what I know such a switch should be ok. Unfortunately with no result....... Still no sound.
  • 01-25-2012 9:18 AM In reply to
    Re: CD 50 no sound
    Silly question praps,but have you got the cables mixed up?Beogram cd cables are marked "phono".Could you be using the tape cable?
    Have you tried connecting the cd50 via the rca connectors rather than din,just to check that sound is def not coming out of the player?
    The disc won't start when you load it manually,only when you press play with the drawer open.
    Nick
  • 01-25-2012 3:21 PM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 no sound
    solderon29:
    Nick
    No, I'm sure I use the right cable and yes, I have tried connecting the cd50 via the rca connectors rather than din. But thanks anyway for your suggestions. Sometimes these mistakes happen.............
  • 01-25-2012 4:47 PM In reply to
    Re: CD 50 no sound
    It's worth checking if F3 (1.6a fuse)on the fuse board to the rear of the cd mech has blown.I've had this go for no apparent reason.It supplies the voltage for the main muting circuit.Otherwise,double check all interconnecting cable looms  are in place.
    If still no joy,you will need to do some signal tracing.Do you have a manual?
    Nick
  • 01-26-2012 4:04 AM In reply to
    • riis
    • Denmark
    • Posts 152
    Re: CD 50 no sound
    solderon29:
    Nick
    Thanks Nick. I'll check the fuse. I have a scanned service manual in a poor quality, but I have no experience in signal tracing.
    /riis
