Hello
I have owned a pair of beauty beovoxs120 and it is my first post here.. :)
I have a problem with a subwoofer included beovox S120. When playing music with a clear low tone, system overload shut off the left column. I noticed also, when I jumped in front of the speaker, I heard a strange sound (same as the short circuit wires). Is it possible to the wire under the influence, the shock has been closed? Does anyone have a manual and had a similar problem?
Thanks for any hints.
best
Radek
