Latest post 08-01-2007 9:33 AM by Westlander. 2 replies.
Page 1 of 1 (3 items)
  • 08-01-2007 7:27 AM
    • Westlander
    • Not Ranked
    • Joined on 04-17-2007
    • Monster, the Netherlands
    • Posts 64
    Beocenter 2500: is it possible to listen to LW?
    according to the specs BC2500's tuner has FM, AM and LW.
    Can anyone tell me how to select LW on BC2500? I cannot find it, and I need it.
    Please, help!
    kind regards,
    Paul
  • 08-01-2007 8:34 AM In reply to
    Re: Beocenter 2500: is it possible to listen to LW?
    Can't you just select AM and then put in the frequency you want? It is supposed to have LW according to the specs.
  • 08-01-2007 9:33 AM In reply to
    • Westlander
    • Not Ranked
    • Posts 64
    Peter,
    thanks for answering. Indeed I can select FM, or AM which scales from 0 to somewhere > 1600. I suppose LW is 'included' in AM.  So there is no separate LW-band to choose, I understand.
    Thanks,
    Paul.
