Latest post 07-31-2007 6:30 AM by rayfenwick. 5 replies.
Page 1 of 1 (6 items)
  • 07-30-2007 7:21 PM
    Beocom 2000 help wanted
    Hi all
    I have just bought a Beocom 2000 on eBay as faulty.  I have noticed it has no battery in it...  the battery compartment says 36v - if this is true, what on earth battery is it, and where can I get one from? Do we have any Beocom experts on the group?
    Many thanks in advance for help
    Ray
    Ray
    Я люблю Банг и Oлуфсен
  • 07-30-2007 7:38 PM In reply to
    Re: Beocom 2000 help wanted
    Not sure where you would get the battery, but ive just read on beocentral that the battery is in case the phone was disconnected or moved, a lithium battery maintained the memories. So when plugged in you shouldnt need a battery. Hope you can fix it.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 07-30-2007 7:44 PM In reply to
     Found the battery here 11th battery down. The battery is in fact 3.6V
  • 07-30-2007 7:46 PM In reply to
    no expert in this but,
    it's a 3,6V lithium battery, it no longer available from B&O. it will work with out it, just have no memory if unplugged..
  • 07-31-2007 2:02 AM In reply to
    The suggested battery will be fine and cost around £6
    Regards Keith....
  • 07-31-2007 6:30 AM In reply to
    Thanks to all for your advice on this one.  I as thinking 36v is a bit strange for keeping CMOS data.. :)
    Anyway, as you all say the phone should work without this battery, and it is as dead as a doornail, I think I'll have to take it apart and have a look.
    My friend thinks it looks like a childs toy phone (it is the bright red one with multicolour buttons) and is quite amused, but I still for some reason really like it.. :)
    it is a pity there's no caller ID on these (I don't think it was invented :) ) but other than that....
    I'll let you know of any progress once I get it on the bench.
    Ray
    Ray
