Hi Dennis,
if you want the photo to appear in the Photo Gallery you need to email it to moderator eduard as he looks after this section at present.
If you merely want to attach it to a post then go to the options tab at the top right hand side of the text box and then to Add/Update where you can add the photo.
Chris.
