Latest post 08-20-2007 6:41 PM by Alex. 14 replies.
Page 1 of 1 (15 items)
  • 08-19-2007 12:12 PM
    Beolab 5000's vs. 4500's
    Any imput out there of BO'ers that have owned or heard the two of these compared???
    It seems that the 4500's had active equalization......did the 5000's also???
    Thanks,
  • 08-19-2007 2:37 PM In reply to
    Re: Beolab 5000's vs. 4500's
    Active equalisation means that the spec says that the bass was slightly boosted in the 4500 to compensate for the smaller cabinet.
    I tend not to believe a lot of the marketing hype which surrounds the writing of specifications. As far as sound goes, the 5000 is just a bigger sound all round. Brighter and more in your face than, say, Pentas. I prefer my 5000's to Pentas.
    The performance seems influenced by the construction of the wall that you hang them on. My walls are timber frame (stick built as in US) and this seems to give more bass than solid construction.
    If you are looking for 5000's then good pairs are as rare as hens teeth and command premium prices.
    Regards Graham
  • 08-19-2007 2:55 PM In reply to
    Thanks Graham....so are the parts for 5000's also available from the dealer???  Aluminum panels, fabric, frets, etc??
    THanks, K
  • 08-19-2007 3:04 PM In reply to
    Alas no, that's why mint examples fetch high prices.
    Regards Graham
  • 08-19-2007 3:22 PM In reply to
    What i'm wondering about with those is: with which system they were supposed to go with: imho they don't go with any because of the orange displays and stainless steel whereas most/all sets from that time were aluminium and red led indicators.
    I was hoping (when i got my pair kind of by coincidence) they had a receiver for the beolink remote in them, so one could use them as link speakers, but no...(so now i have them combined with a no matching 3500 set, gonna change it soon to a lesser no matching 4500 set.
    Another thing i don't understand is why they haven't put a proper double (2-way) amp in, one for high and one for low instead of just sticking an amp under a passive speakerbox (but i guess this is also the answer.....), after all even in tv sets with active speakers they did this..(MX7000, Avant...).
    Otherwise they do sound fine for such a type of (flat) speaker.
     Now maybe i'm missing something...who knows....? :)
  • 08-19-2007 3:50 PM In reply to
    So Graham.....Can i recover the cloth portion of the 5000's using colth from BnO??? Has that been done??
  • 08-19-2007 3:52 PM In reply to
    Also Graham....are the woofers rubber or foam surround??
  • 08-19-2007 4:33 PM In reply to
    RubberBig Smile
    Regards Graham
  • 08-19-2007 4:50 PM In reply to
    Thanks Graham.....do you think that it could be a home project to recover with the speaker cloth??? since the frets are no longer available..??
  • 08-19-2007 5:02 PM In reply to
    Shouldn't be too difficult but as I have said before, not to my taste. If it's not genuine, I don't want to know.
    Regards Graham
  • 08-19-2007 6:38 PM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    A few additional comments.
    The 4500's were continued to a much later date that the 5000's from memory. The 5000's are very large speakers, check the measurements. Even use a stencil on the wall. Check the amplifiers for both. If they fail you will end up with Beovox4500/5000 speakers.
    Transport of the speakers can be a problem. So they best found locally.
    I have the 4500's which are great speakers and they made it from Europe to Australia. So they can be packaged and delivered safely. Though I do consider myself very very lucky.
    B&O, IMHO, should re-produce these panel speakers but with their new technology.
    BTW remember to get the wall brackets...
    Beoaus.
  • 08-20-2007 4:55 AM In reply to
    • dylan
    • Top 500 Contributor
    • Perth, Australia
    • Posts 117
    beoaus:
     My 4500s making the same journey next month - fingers crossed Unsure
    Dylan
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
  • 08-20-2007 7:19 AM In reply to
    • beoaus
    • Posts 445
    Dylan, You just have to take the risk don't you....
    I'd cross a few other body parts as well.. Surprise
    Beoaus.
  • 08-20-2007 4:45 PM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    Crossed and double crossed. Busy doing my insurance - anybody care to hazard a guess at the "as new" replacement cost of BL4500s, BG5500, BG4000 in Australia...[:'(]
  • 08-20-2007 6:41 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    I actually think the panel speakers are something B&O could easily do a limited re-production run of. Other 'best of' products, such as the BeoSystem 7000, AV9000, BeoCenter 9000, and Penta are often talked about as being some of the best bits of B&O to come across, but never the panel speakers. It's almost like they've been 'forgotten'. Indeed, I've only ever seen three pairs in person, only one pair of them actually set up and running on location, and I think that's pretty good going considering I generally don't actively look for them! Shame really, they sounded and looked pretty fantastic.
     Weekly top artists:
