Latest post 12-27-2011 7:57 AM by Guy1680. 3 replies.
Page 1 of 1 (4 items)
  • 12-27-2011 5:41 AM
    Avant showing red horizontal lines on screen
    My Avant was purchased in 1997, VCR model. Recently the screen has started to flicker and to show red tinted screen with red horizontal lines, instead of the transmitted picture. Is this a sign that my tube is about to blow?
  • 12-27-2011 6:17 AM In reply to
    Re: Avant showing red horizontal lines on screen
    Unfortunately yes, that does sound very much like the tube is on it's way out.
    Sadly too, the value of these sets are so low now that it would be uneconomic to replace the tubeSad
    On the positive side, you can pick up another Avant for very little money - less in fact than it would cost you to fix your existing set.
    Regards
    Michael
    BV5, BV Avant, MX4000, MX1500
    BS 7000, BS 5500
    Penta III, Penta II, BL 4000, RL 60.2,  RL 35, CX-100 Alu
    BL 7000, MCP6500, MCP5500,  BL 5000,  Beo4 (x2), BL 1000 (x2)
  • 12-27-2011 6:33 AM In reply to
    Many thanks Michael.
  • 12-27-2011 7:57 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Slight red lines could be a problem with the 'G2 adjustment' (screen voltage for the red tube, I believe) - my BV3 had this problem about a year ago, and a small adjustment sorted it.  I fixed mine myself using the service manual available on site but I wouldn't recommend taking the back off your TV unless you know what you are doing - there are very high voltages inside!
    If you have a friendly TV engineer it could be worth 30 mins of his time before deciding to scrap the TV.
