Latest post 08-15-2007 6:21 PM by Jandyt. 10 replies.
Page 1 of 1 (11 items)
  • 08-13-2007 2:56 PM
    What master would you rather have ????? (IMPORTANT PLEASE)
    I've been looking at Radix's Ipod conversion for the Beocenter 9500....full conversion with remote control of the Ipod...(i've got 2500 songs on my Ipod).... Should I use that for the Whole house master.....(of course do a ML/MCL converter to Masterlink to all the Actives and Passives)....
     OR
    Should I stick with the Beosound 9000 with only 6 CD's???????????????????
     Could I remote through a Passive or Active Kit thru the ML/MCL converter to the Beocenter 9500 and control the Ipod from anywhere???????
     Graham........, Peter..........................anyone.....HELP !!!
     THanks, k
  • 08-13-2007 3:13 PM In reply to
    Re: What master would you rather have ????? (IMPORTANT PLEASE)
    Do you know if it uses Datalink from the BC or receives Ir from the remote?
  • 08-13-2007 3:20 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    If your Beosound 9000 is a MK 2 or MK3 then I would get Beoport. This will give you access to all you MP3's plus over 3000 radio Stations. If you do have a MK 2 Beosound 9000 then it may need an SW upgrade first.
    CraigSmile
  • 08-13-2007 3:22 PM In reply to
    • Craig
    • Posts 4,855
    The Stig - ver. 1.27:
    It uses Datalink as far as I know.
    CraigSmile
  • 08-13-2007 3:34 PM In reply to
    Craig:
    CraigSmile
    Thanks! I will suggest the same as you Craig, thats the B&O way and the best way IMO
  • 08-13-2007 5:16 PM In reply to
    Craig:
    CraigSmile
    Why only Mk2 or 3?
    Regards Graham
  • 08-13-2007 6:11 PM In reply to
    I would get the Beoport - or I should say - I have got a Beoport! Laughing ( I have 16,000 tunes on iTunes!)
  • 08-13-2007 7:04 PM In reply to
    The equipment is in South America (colombia) it's real 3rd world.....so no sat. radio... I really don't know anything about Beoport, MKII or III......as it pertains to a Beosound 9000......??????????????/
    How do I get Beoport...???
  • 08-13-2007 7:21 PM In reply to
    Beoport is a black box you connect to you PC and then to Master link. then it's possible to play all music you have on your PC over Master link and controlling it by BS9000. Also there is over 3600 radio stations from the web.
    I can't find anything saying it's not possible to upgrade mrk 1 to having N.Music???
    BTW you buy it from your B&O dealer.
  • 08-14-2007 3:08 AM In reply to
    My point exactly. AFAIK all BS9000 can be upgraded for N Music. See FAQ on the subject.
    Regards Graham
  • 08-15-2007 6:21 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Thanks Graham.
    AFAIK has been added to THIS THREAD
    Poor me, never win owt!
