Latest post 12-07-2011 12:59 PM by riegado. 8 replies.
Page 1 of 1 (9 items)
  • 11-27-2011 12:29 PM
    How to use Beo4 Remotecontrol to redirect A.Aux to AV
    Hello
    I am new hire and have less experience with B&O looking for help!!
    Have a BeoSound 4 with speakers and BeoVísion connected with a MasterLink cable and a Beo4 remote control.
    I am able to send the radio sound to the TV by using the Beo4 Key <List> until AV is in the display followed by the key <Radio>. Then the TV switched on (without screen) and Speakers playing radio music. So far so good.
    A friend of me is DJ and we connected his equipment to BeoSound4 to AUX-in, with Beo4 switch to with key <List> A.AUX , then the standard speaker worked fin. I do not find any key combination to redirect the A.AUX sound to the TV as I can do it with the radio.
    Dose anybody know the Beo4 key combination?
    Thank you
  • 11-28-2011 2:34 AM In reply to
    Re: How to use Beo4 Remotecontrol to redirect A.Aux to AV
    I´m quite sure it is not possible. Of some reason B&O have not been thinking of that scenario.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 11-28-2011 4:48 AM In reply to
    • petermc
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Depending on the version of your Beo4 - does it have a A-Tape button (under the Cd button)?
    If so, try List AV then A-Tape.
    I'll see if I can find another key combination.
  • 11-29-2011 10:42 AM In reply to
    Hi petermc
    my beo4
    has
    TV      Light     Radio
    DTV     DVD      CD
    V.Mem Record A.MEM
    Thx
  • 11-29-2011 11:41 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    As both the "AV" and "A.AUX" commands are accessed via the list button on the Beo4 remote control, I don't think it is posible to acheive what you are trying to do. However a Beo5 or Beo6 could have a button created that could send the command "AV - A.AUX". That would do the trick.
    Opman
  • 11-29-2011 12:28 PM In reply to
    AV A.MEM will do the trick
  • 12-01-2011 5:53 AM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    Carolpa:
    Won't that select the SD card on the BeoSound4 rather than the A.AUX socket?
    Opman
  • 12-01-2011 6:17 AM In reply to
    your right; didn't think about the SD
    the machines with only a CD like the BS3000 and the BS9000 the commands ATAPE and PHONO open the AUX input
    so he should try the AV PHONO instead
  • 12-07-2011 12:59 PM In reply to
    Hi
    Thank you for all the answers :-)
    with the remote control Beo4 it is definitely not possible to get this done!
    I got an other solution, connect the external device to the BeoVison and use the v.Mem. Then I can redirect the sound to all speakers.
    regards
    riegado
