Latest post 12-03-2011 1:09 PM by mediabobny. 1 replies.
Page 1 of 1 (2 items)
  • 12-02-2011 10:12 AM
    Beosystem 2300 - Doors do not close completely.
    Hi..
    The doors on my above unit, will periodically not close completely ?
    We are talking about a couple of inches. And this only happens here and there ?
    Any input ...
    Jesper
  • 12-03-2011 1:09 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beosystem 2300 - Doors do not close completely.
    It happens to all those old models (2500/2300/4000) at some point.  Try cleaning the slider tracks with Q-Tips dipped in some kind of cleaner (I use Windex).  Then spray a lubricant in the tracks (I use Silicone spray).  If this doesn't cure it it's off to the repair shop (or remove the doors).
