Dear all,
BM5500, Beolink 'ready' (sticker on the rear) with software version 2.3.
MCL cable
Xtra speakers kit (transceiver and relay box)
I've plugged the MCL cable into 'speakers 2' on the BM. I stripped back the coloured wires on the other end and connected them to the corresponding pins on the relay.
Question: is the black lead supposed to comprise white nylon instead of actual wire?
Question: is the white 'data' cable supposed to be stripped back? There's silver wire wrapped around the exterior of a white plastic casing, in which sits silver wire. Not sure how this is supposed to be prepared. I stripped the plastic coating to reveal the wire inside, then pulled some of the outer wire forward so both are in contact with the binding pin. Is this right?
I screwed down the MCL cable clamp and started on the tranceiver connections. Stripped back the wires and connected them to the corresponding pins in the relay box.
Question: there's a piece of 'string' running through the outer casing. What's this for? Should this be screwed into one of the binding pins along with a wire?
I left this unconnected and clamped down the transceiver cable.
I connected my Xtra speakers (Beovox 1702s).
Pointed the Beolink at the transceiver and pressed 'Link' '2' and then 'Store' as recommended in the Xtra Speakers kit instructions.
LED on the transceiver blinked.
What works: the 'Mute' button on the transceiver works. If I'm playing a tape in the main room the sound is reproduced through the link speakers in room 2.
When I press the 'Mute' button on the transceiver again the sound is muted on the room 2 speakers but not on the main system.
What doesn't work: commands from the Beolink to the BM via the transceiver. Volume, source, Mute. Non of those functions work. The transceiver blinks the LED each time the Beolink buttons are pressed but no commands are sent to the BM.
However - once I pressed the off (little red) button on the Beolink 1000 whilst pointing at the transceiver and the speakers in room 2 muted. This was not possible to replicate, it was a one off.
Have I missed a trick somewhere?
I'd be ever so grateful for any assistance on this.
Kind regards
